Heater control switch - JeepForum.com
post #1 of 7 Old 05-30-2006, 10:31 AM Thread Starter
cruzer63
Has anyone else had a problem with their heater control switch, I can't switch between heat defrost or anyother settings seams to be stuck in the defrost position. Thanks for any suggesttions
cruzer63 is offline
post #2 of 7 Old 05-30-2006, 10:36 AM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Check for a vacuum leak. The heater box defaults to defrost mode, so if there's no vacuum to move the doors, that could be your problem.
I'll be Savvy someday!
neZZr is offline
post #3 of 7 Old 05-30-2006, 10:51 AM
brossie
Pull the knob off and see if it's broken on the back. Common problem.
brossie is offline
post #4 of 7 Old 05-30-2006, 10:56 AM
neZZr
neZZr's Avatar
Hehe... that'd be a moment
neZZr is offline
post #5 of 7 Old 05-30-2006, 12:24 PM
Thetrav5.9
Thetrav5.9's Avatar
I wish that was my problem.....I have a broken arm on one of my canisters
Jus Kiddin...but not really
Travis
Thetrav5.9 is offline
post #6 of 7 Old 05-30-2006, 12:39 PM
stogie25
stogie25's Avatar
This problem is chronic in Jeeps. It was discussed in this thread.
Good luck,
http://www.jeepforum.com/forum/f9/vents-acting-up-274269/
Jarhead Jeep Club
O|||||||O
97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders.
My Build Thread
stogie25 is offline
post #7 of 7 Old 05-30-2006, 02:07 PM
Ole Yeller
Ole Yeller's Avatar
2010 JK Wrangler
brossie's suggestion worked for me.
2007 Patriot Limited
2006 Unlimited Rubicon
2006 Commander
2000 TJ Sport
My previous Jeeps
1992 Wrangler S (Ole Yeller)
1985 Cherokee Pioneer
1989 Cherokee Laredo
1995 Cherokee Country
1996 Cherokee Country
1996 Grand Cherokee Laredo
Ole Yeller is offline
Heater Control wolf3902 YJ Wrangler Technical Forum 6 01-26-2011 01:16 PM
heater switch?? rustyc TJ Wrangler Technical Forum 3 12-22-2008 09:09 AM
AC/Heater Control Switch jrclark3 TJ Wrangler Technical Forum 5 03-11-2007 07:00 AM
heater vac switch? Richmond88yj YJ Wrangler Technical Forum 7 02-23-2007 11:31 AM
