Heater blowing but blowing hard - JeepForum.com
post #1 of 3 Old 12-29-2009, 03:19 PM Thread Starter
fireman879
i have a 1999 tj and the heat works fine except when i turn up the blower it sounds like it is blowing hard but it dosent change in any vent.
it is starting to get colder here so in return i am starting to freeze my butt off inside my jeep.
it is my daily driver so i really need to try to find out what would be causing it not to "blow" right.
thanks
david
fireman879 is offline
post #2 of 3 Old 12-29-2009, 07:27 PM
Longoddr1
Check to see if it is blowing at the defroster for the windshield. This is the default direction in case of a vacuum control failure. Let us know what you find.
Longoddr1 is offline
post #3 of 3 Old 12-29-2009, 09:08 PM Thread Starter
fireman879
I checked the vacuum and everything works right changing from defrost to feet etc. but the force of the air never changes when i turn the speed of the blower up.
Heater not blowing hot Marholmes44 TJ Wrangler Technical Forum 1 12-17-2008 12:46 AM
Heater fan blowing air fireman413 TJ Wrangler Technical Forum 1 12-10-2008 06:20 PM
Heater Not Blowing Hot dualtjs TJ Wrangler Technical Forum 7 04-01-2008 12:52 PM
Heater/AC not blowing! xtremexp TJ Wrangler Technical Forum 13 02-07-2007 04:50 PM
Heater keeps blowing hot air... YKnot YJ Wrangler Technical Forum 3 05-19-2005 10:18 AM
