Heater/AC vent problem - JeepForum.com
post #1 of 7 Old 11-29-2005, 11:52 AM Thread Starter
blang4d
I'm having a problem with the dashboard heater/ac vents in my Jeep. (97 TJ) The windshield defroster and lower (foot) heater vents work, but the dash vents seem to be blocked or clouged. Does anyone have any advice as to what it is/how I fix it?
blang4d is offline
post #2 of 7 Old 11-29-2005, 12:15 PM
Jeepdrivinmid
Jeepdrivinmid's Avatar
Yeah I've got the same problem. No matter which setting I put it on all I get is windshield and foot vents. I've taken the dash off and cant see a problem. Any help?
Mikey..2000 TJ Sport
Jeepdrivinmid is offline
post #3 of 7 Old 11-29-2005, 03:00 PM
Tonka
2015 JK Wrangler
the arms attached to the vaccuum actuators under the dash likely broke.
they are plastic and break easily. they may still be in place, but wont work if the small clip portions break off
I had to replace all of them on my 98tj including the one that is cable operated for the hot/cold door
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #4 of 7 Old 11-29-2005, 10:04 PM
rob15b10
where exactly are the arms/vaccuum actuators located under the dash? I have the same problem.
Robert Olcott
rob15b10 is offline
post #5 of 7 Old 11-29-2005, 11:11 PM
CreightonRea07
they are located under the dash on the drivers side. You should see a large group of brightly collored vacum lines, leading to vacum actuators w/ move the levers
Me:
2000 TJ Sport
Dana 44
4.0L 5-speed
33x12.50 bfg Muds
MORE sport cage
re 4.5 w/ 3.5 springs
Little Brother:
'92 Cherokee Laredo
Stock but soon to be lifted
235/75 BFG All-terrains
lots of dings and scratches
CreightonRea07 is offline
post #6 of 7 Old 11-30-2005, 07:44 AM Thread Starter
blang4d
If these arms are what's broken, how hard are they to replace? Where would I go to get new ones?
blang4d is offline
post #7 of 7 Old 11-30-2005, 08:10 AM
ncb76
ncb76's Avatar
http://www.jeepforum.com/forum/showt...6&page=1&pp=15
Read that thread, it should help you out. The first thing you need to do is check to make sure you don't have any vacuum hoses loose. If they are fine, chances are one of the actuator arms has broken. It's a fairly easy fix, but space is tight so it's a pain.
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline
Air leaking from heater vent? superjet86 YJ Wrangler Technical Forum 3 02-04-2009 10:40 PM
Heater/Air Vent Problem jrs948 TJ Wrangler Technical Forum 0 06-11-2008 12:48 PM
Heater Vent HELP!! Mrwazmo YJ Wrangler Technical Forum 7 09-20-2007 08:21 PM
heater / vent question jeep75 YJ Wrangler Technical Forum 6 10-20-2004 11:55 AM
heater/vent problems Joe jeep YJ Wrangler Technical Forum 4 03-26-2004 03:35 PM
