heater - JeepForum.com
post #1 of 8 Old 02-01-2007, 09:25 PM Thread Starter
poncerstj
heater
my heater is not workin. on startup its cold. i drive down the road its cold. after the jeep heats up completely it comes on a little bit, but its still not as hot as it was before. ive put in an airraid cold air intake and i thought it was cause of that but lately ive been thinkin its a clog in the hose. someone help me out i go to appalachian state and im freezing my *** off!
poncerstj is offline
post #2 of 8 Old 02-01-2007, 09:28 PM
Rocky529
Rocky529's Avatar
Have you tryed flushing your coolant?
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 8 Old 02-01-2007, 09:48 PM
KRV
If that doesn't work try replacing your thermostat.
If that doesn't work try replacing the water pump
If that doesn't work you may need a new heater core
KRV is offline
post #4 of 8 Old 02-01-2007, 09:50 PM
Rocky529
Rocky529's Avatar
I can't see that as the probable cause because supposedly his Jeep is getting up to temp.
Rocky529 is offline
post #5 of 8 Old 02-01-2007, 10:02 PM
KRV
I had the same problem and it was my thermostat. Anyway, it's such a cheap fix and a good starting point you may as well switch it out.
KRV is offline
post #6 of 8 Old 02-02-2007, 07:18 AM
Maximum Carnage
2002 KJ Liberty
I've heard that if you replace the grill that is right underneither your windshield with one of this it will help. Has anyone tryed it? Anyone heard of it?
Maximum Carnage is offline
post #7 of 8 Old 02-02-2007, 07:29 AM
thesherm
thesherm's Avatar
it seems to me that would increase air flow but not air temp, so you would just have more cool air coming in
98 Sahara
Originally Posted by mrblaine
Unfortunately you are one of those poor misguided folks that believes leaving the gear shift lever in one slot or another is an indication of control.
Come go for a ride and I'll be glad to demonstrate the difference between what you perceive incorrectly as "control" and what control actually is.
Pick a different reason because that one is both lame and stupid to perpetuate.
Pardon me for damaging your precious reputation. It's not that I disagree, that would be a difference of opinion. This isn't subjective, it's objective, you are just wrong. If you make that statement, you are misguided. It is that simple.
thesherm is offline
post #8 of 8 Old 02-02-2007, 09:26 AM
Rocky529
Rocky529's Avatar
Not needed, that is only for airflow...and even then it is useless.
Rocky529 is offline
Heater Help!!! Eriq35 YJ Wrangler Technical Forum 15 11-25-2011 10:12 PM
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. blackattak TJ Wrangler Technical Forum 4 02-28-2011 04:20 PM
YJ Heater Core and Heater Motor Replacement?? Boston Mangler YJ Wrangler Technical Forum 11 11-29-2009 08:31 AM
Heater Help jeepers2112 TJ Wrangler Technical Forum 1 02-19-2009 06:36 AM
Heater ? allmopar YJ Wrangler Technical Forum 3 01-29-2007 04:57 PM
