heat soak issue on 4.0L - JeepForum.com
post #1 of 20 Old 08-12-2010, 06:54 PM Thread Starter
tjdriver
i know there are a few jeepers out there with the heat soak issue on the 4.0.
i'm one of them. i read and applied the tsb and to no avail. time after time my jeep has hesitated and ran rough after running to the store. i've read a few threads that say the ethanol content in gas is partially to blame.
i found some ethanol free gas at a local station. it was $.10 more than every other gas station around but so far it is worth it. i have only burned a quarter of a tank out so far but i have not had the rough idle after a quick run to the store. i'm going riding with my jeep club this weekend in MS and hope to ahve the same results. i will report back when i get back on sunday.
tjdriver is offline
post #2 of 20 Old 08-12-2010, 07:10 PM
jeepin-gheenoe
sounds good man! let us know!
i dont have this problem with my jeep...but my 1981 15hp evinrude on my gheenoe...exact same senerio with yalls jeeps, i hope this is why she runs bad when hot.
thanks again!
2005 Wrangler LJ (patriot blue with matching body&fenders like a sahara), auto, D44 rear Limited Slip Diff, D30front open, 3.73, 1 1/2inch RC spacer lift, K&N CAI, 31/10.50 kelly safari tsr A/T's, custom grill guard, warn 3700 winch, 5" KC Apollo long range lights, 1500watt SSL amp pushing a 12 inch kicker CRV sub, Flowmaster 40seriers muffler with custom side exit crome tip and lots of CROME!
Have an LJ and need a hard top...clicky here!
Check out my Jeep and my Gheenoe in
actoin on my youtube Channel
Originally Posted by AlexTJ View Post
While we're at it lets sue the pants off 'em for ever considering using the dana 35!
Originally Posted by TJorange View Post
Your Jeep is a real work horse man! Seems like ive seen at least one picture of it on every page of this forum.
jeepin-gheenoe is offline
post #3 of 20 Old 08-12-2010, 07:47 PM
BYuen
BYuen's Avatar
Hey you'll get better gas mileage too with ethanol free gas! I've tried for the life of me but could not find a gas station around my area that doesn't have the ethanol junk in it
BYuen is offline
post #4 of 20 Old 08-12-2010, 09:15 PM
Apex
Recon death squad
Apex's Avatar
I have had issues with heat soak/vapor lock twice...both times on the trail with +90 degree temps. Try starting your Jeep with the AC on when you are having those issues. It makes it SOOO much worse
Apex is offline
post #5 of 20 Old 08-12-2010, 09:25 PM
2006_Sport
I thnk that was the issue I've been having with the rough idle was heat soak. It's been 90+ degrees here in NC and it just stopped doing it today...after I floored it a few times Idles great now.
2006_Sport is offline
post #6 of 20 Old 08-12-2010, 09:27 PM
Apex
Recon death squad
Apex's Avatar
Yup, you gotta really blow that **** out...
Apex is offline
post #7 of 20 Old 08-12-2010, 09:50 PM
rs4race
what is "heat soak" in the jeep world? I only know of it in turbo charged applications... Heat soak dealt with intercoolers getting hot from being parked and the heat of the engine soaking them. More prominent in top mount intercooler situations.....
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline
post #8 of 20 Old 08-13-2010, 05:45 AM Thread Starter
tjdriver
i went to have my echo weedbeater fixed and they guy told me the diaphragm was shot. he said it's the ethanol content in the gas that makes them wear out prematurely. i told him that chit is making my motor in my jeep unhappy and he said there was a gas station just down the road that has ethanol free. i filled up that day and she's doing good so far.
Fuel System - Hot Start Misfire/MIL ON/DTC's/Rough Idle
NUMBER: 18-031-03
GROUP: Vehicle Performance
DATE: Sep. 05, 2003
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 18-027-02, DATED SEPTEMBER 06, 2002, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A COMPLETE REVISION AND NO ********S HAVE BEEN USED TO HIGHLIGHT REVISIONS.
SUBJECT:
4.0L Rough Engine Idle After Restart Following A Hot Soak
OVERVIEW:
This bulletin involves the installation of a fuel injector insulator sleeve.
MODELS:
2000-2004 (TJ) Wrangler (Domestic and International Markets)
1999-2004 (WJ) Grand Cherokee (Domestic and International Markets)
2001-2004 (WG) Grand Cherokee (International Market)
2000-2001 (XJ) Jeep Cherokee (Domestic and International Markets)
NOTE: This bulletin applies to vehicles equipped with a 4.0L engine (sales code = ERH)
SYMPTOM/CONDITION:
Customers may describe a 20 to 30 second rough idle following the restart of a heat soaked engine. This condition may be most noticeable when the engine is restarted following a prior 10 to 20 minute heat soak in hot ambient conditions of approximately 32C (90F) or higher. This condition may be consistent with short city stop-and-go driving trips and can be aggravated by the use of fuel with a high ethanol content. Depending upon various conditions a MIL may occur due to DTC P0303 - Cylinder # 3 Misfire.
This condition may be caused by heat from the exhaust manifold that following engine shut down migrates to the area around injector # 3 and causes fuel vapor to form within the injector. This in turn may cause a momentary misfire of cylinder # 3 until the fuel vapor is cleared of injector # 3. The insulator sleeve lowers the injector # 3 temperature to a point below which the fuel will not normally vaporize.
DIAGNOSIS:
1. If vehicle exhibits a rough idle, and if a misfire of cylinder # 3 is observed following a 10 to 20 minute hot soak, perform the Repair Procedure.
PARTS REQUIRED
REPAIR PROCEDURE:
1. Cut insulator sleeve, p/n 56028371AA, to make two (2) insulator sleeves about 25-30 mm (1 in.) in length.
2. Install one sleeve around injector # 3, with the slit on the upward facing side of the injector. Install the other sleeve with the slit on the downward facing side of the injector.
3. Confirm sleeve is flush to intake manifold surface around injector.
4. Check injector # 3 wire and ensure that the injector is rotated to a 2 o'clock position (from driver's side of vehicle).
tjdriver is offline
post #9 of 20 Old 08-13-2010, 09:04 AM
BYuen
BYuen's Avatar
I wrapped some tin foil around my #3 injector. I think it helped a little, but it's not enough. I'm gonna have to wrap the rest of the injectors and the entire injector rail and see how that goes. Or I guess I could spend some money and get that TSB insulator lol
BYuen is offline
post #10 of 20 Old 08-13-2010, 09:08 AM
pwcracer
This is exactly what my Jeep does on the trail. It's such a PITA I don't like shutting my jeep off..
pwcracer is offline
post #11 of 20 Old 08-13-2010, 10:04 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
i just floor the gas pedal after the heatsoak rough idle. once it hits near WOT, the fuel moves through and the MAP sensor takes a reading, all is normal.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #12 of 20 Old 08-13-2010, 10:14 AM
Apex
Recon death squad
Apex's Avatar
Exactly what I do.
Apex is offline
post #13 of 20 Old 08-13-2010, 10:21 AM
Dogman
Dogman's Avatar
That's been my experience on the trail as well. I had someone ask me if my Jeep was carbureted - totally annoying
John 3:17
Dogman is offline
post #14 of 20 Old 08-15-2010, 05:27 PM Thread Starter
tjdriver
^^^^ lol.
my jeep ran a heck of alot better and i had better mpgs off the non ethanol gas.
we played in a huge sand pit and it was hot as you know what until it started pouring.
i didn't hesitate to shut my jeep off when we stopped for a few minutes like i normally would.
i did have a slight hesitation upon start up, but no where near what i had before. it only had the hesitation once
or twice, but like i said it poured on us. i'm going to continue running the ethanol free gas in the jeep.
tjdriver is offline
post #15 of 20 Old 08-15-2010, 06:26 PM Thread Starter
tjdriver
forgot to add that when i filled up with ethanol free i was at 1/4 of tank of the ethanol stuff. i just filled up again and figure it may be out after this tank or the next and i should see true results.
tjdriver is offline
heat soak , tsb insulation , vapor lock
my TJ heat soak issue... urstolendesire TJ Wrangler Technical Forum 93 07-14-2014 11:27 AM
Heat Soak in a YJ RickyZJ YJ Wrangler Technical Forum 5 07-28-2010 08:32 PM
It is nice out...and heat soak is back Deezul TJ Wrangler Technical Forum 3 04-07-2010 08:07 PM
These JK's soak up the heat!!! LHS-Cowboy JK Wrangler Technical Forum 36 09-03-2009 09:03 PM
heat/ac issue lokua TJ Wrangler Technical Forum 7 05-10-2007 02:58 PM
