Heat out ? - JeepForum.com
post #1 of 8 Old 10-25-2013, 02:54 AM Thread Starter
FleXJ96
2010 JK Wrangler
Heat out ?
Going for a wheeling /camping trip tomorrow and the heat decided to stop working . What should I trouble check. It's a 98 4.0. Blows air , just not heat . AC is currently bypassed but that shouldn't matter , should it ?
FleXJ96 is offline
post #2 of 8 Old 10-25-2013, 03:04 AM
bailz812
thermostat stuck open or heater core clogged.
bailz812 is offline
post #3 of 8 Old 10-25-2013, 08:43 AM
rubicon17
pull both lines off going into the heater core, but not at the firewall, do it on the engine side and use a hose to back flush the heater core. is your temp gauge acting normal?
rubicon17 is offline
post #4 of 8 Old 10-25-2013, 11:49 AM Thread Starter
FleXJ96
2010 JK Wrangler
yes temp is good at 210, hose are hot when running, thinking core might be clogged
FleXJ96 is offline
post #5 of 8 Old 10-25-2013, 02:52 PM
rubicon17
yea try back flushing it like i mentioned just pop the hoses off where it connects to the engine and run a water hose through each one you will be surprised all the junk and comes out when the pressure goes the opposite way, it worked great on my xj when i first got it and its been hot ever since.
post #6 of 8 Old 10-25-2013, 03:34 PM
number40Fan
2014 JK Wrangler
Are both hoses hot? If so, I bet that you have a blend door that isn't switching to hot. Turn the blower on and change the temp setting from hot to cold. Do you hear a change in air flow?
number40Fan is offline
post #7 of 8 Old 10-25-2013, 05:54 PM
sawoodhick
if the blend door isn't switching, do I have to replace the heater core or is there another option?
sawoodhick is offline
post #8 of 8 Old 10-25-2013, 07:37 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
You can fix/change the blend door actuator and/or the linkage without changing the heater core...
Knuckelhead is offline
