heat/AC control panel issues - JeepForum.com
post #1 of 3 Old 11-06-2008, 08:38 AM Thread Starter
DonziJeep
I have a 98 TJ wrangler. At night when i turn the lights on the heat/AC control panel does not light up. Is this normal for all TJ's or is there a light or fuse that i need to replace?
Thanks!
DonziJeep is offline
post #2 of 3 Old 11-06-2008, 09:50 AM
Maverick906
No I don't think that is normal. My AC controls light up when I turn my lights on. Probably a fuse. Does your radio light up when you turn your lights on?
Maverick906 is offline
post #3 of 3 Old 11-06-2008, 10:20 AM
SKIBUMM
Yes it is normal for this to not work. Ok it did not work on mine either. It is fused with the rest of the center console and dash. I had to take the center console apart and remove the Heat/AC control panel and replace the bulb which was really fun to find by the way. When I finally found a new one I decided that a good cleaning would be good for it because it was filthy behind it. So I took it all out and started cleaning. When I put it back together the original bulb work fine. But now I have a spare that I can misplace
SKIBUMM is offline
Looking for A/C control panel TJColumbia TJ Wrangler Technical Forum 3 02-20-2009 01:10 PM
Climate control panel help please!!! gqscuba YJ Wrangler Technical Forum 1 12-10-2008 04:28 PM
Instrument panel issues, Help BucketOKarma TJ Wrangler Technical Forum 14 05-15-2008 04:21 PM
help with heat/AC fan issues citizen332 TJ Wrangler Technical Forum 3 04-23-2008 02:50 PM
rocker panel issues wrnglrguy TJ Wrangler Technical Forum 5 08-04-2006 08:52 AM
