Headlights quit working - JeepForum.com
post #1 of 14 Old 01-01-2009, 11:44 AM Thread Starter
kmas0n
I have a 2000 TJ sport. last week I went to drive to work and the headlights would not come on. The parking lights and fog lights came on like normal, just no headlight. I clicked on the high beams and they worked too, Everything except the low beams.
I checked the fusses, they are all good, I replaced the on/off headlight switch and that didn't fix it
I replaced the left multi function switch (blinker) and that didn't fix it either.
There are no obvious abrasions or cuts in the wiring...
whats left?
any help is appreciated
kmas0n is offline
post #2 of 14 Old 01-01-2009, 11:51 AM
never monday
try replacing the bulbs
never monday is offline
post #3 of 14 Old 01-01-2009, 11:57 AM
Cchandler
2014 KL Cherokee
ya, you needs to replace the bulbs. The low beams burnt out but the high beams still work because they are double filament. This just happened in one of my headlights, I just leave them on high until I have the money to just go ahead and get the IPFs and Fatboys! Good luck! Post if that didn't work.
Cchandler is offline
post #4 of 14 Old 01-01-2009, 11:57 AM
Stu Olson
Stu Olson's Avatar
Do you have a voltmeter or a test light?
If so, check on the back of each head lamp to see if you are getting +12V when you turn on the low beams. You can verify your meter or test light is working by checking your high beams since you know they light.
If you get +12V on the low beam contact on the back of the head lamp but it doesn't light, your problem is a bad lamp. If you don't get +12V, then your problem lies elsewhere. At that point, a good factory service manual's wiring diagram is the book to consult.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #5 of 14 Old 01-01-2009, 12:46 PM Thread Starter
kmas0n
I went to parts store to buy a new voltmeter. lol Happy New years. not open today. I'll get back to you guys. I'm thinking its not the bulbs that burned out... although not impossible, its highly unlikely to have two bulbs burn out at the same time. Luckily... I have the factory repair manual from jeep with full wireing diagrams. I have the feeling I'm going to need them
kmas0n is offline
post #6 of 14 Old 01-01-2009, 12:47 PM
never monday
Bulbs are cheap enough at WalMart. Go buy one and plug it in to test.
post #7 of 14 Old 01-01-2009, 12:48 PM
Rocky529
Rocky529's Avatar
My dad's Jeep just had a similar problem and it turned out to be a faulty switch.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #8 of 14 Old 01-01-2009, 12:55 PM
RuffTJ
Im having the same problem with my headlights. Except I know the bulbs aren't out because its only the driver one for me and sometimes it will work perfectly fine and sometimes not at all. i should mention i have the Delta 7" Xenon headlights.
RuffTJ is offline
post #9 of 14 Old 01-01-2009, 12:55 PM
Slithering_Joe
You'll hit yourself for not verifying before buying. Simple easy test/diagnosis. Just like the lottery. It's highly unlikely you'll win but it sure pays out when you do.
4.0L TJ
Slithering_Joe is offline
post #10 of 14 Old 01-01-2009, 12:55 PM
Stu Olson
Stu Olson's Avatar
Was it the hi/low beam switch that he replaced?
Stu Olson
ARB Locked & Loaded
post #11 of 14 Old 01-01-2009, 01:23 PM Thread Starter
kmas0n
Yeah stu it was the high/low switch... also controls the blinker and hazard lights- combo switch. The left blinker always stayed on after a turn anyways so I didn't mind replacing it. I ALSO replaced the on/off pull switch in the dash.
kmas0n is offline
post #12 of 14 Old 01-01-2009, 01:26 PM
Slithering_Joe
TJ Headlamp harness connector:
Wire Color : circuit description
(main color / stripe color)
VIOLET/WHITE : +12V, Low Beam
RED/ORANGE : +12V, High Beam (flash-to-pass)
BLACK : Ground (-)
4.0L TJ
post #13 of 14 Old 01-01-2009, 02:03 PM Thread Starter
kmas0n
Well, as unlikely as it may seem... I got my hands on a test light and there is 12v going to the headlights. It seems both headlights did burn out at the same time. Thanks everyone for your help
kmas0n is offline
post #14 of 14 Old 01-01-2009, 02:17 PM
Slithering_Joe
Time to play the lottery.
4.0L TJ
Blinkers quit working, please help me get them working again. fishmanwill YJ Wrangler Technical Forum 7 01-02-2010 07:46 PM
Headlights turn off randomly? Fan motor quit? Laid-Off YJ Wrangler Technical Forum 3 11-10-2009 07:12 PM
Headlights Quit montanajeepcpl YJ Wrangler Technical Forum 1 09-02-2008 08:22 PM
Headlights quit working nfloyd52 TJ Wrangler Technical Forum 9 04-23-2008 01:14 PM
4H quit working but 4L still works...? rickdrop YJ Wrangler Technical Forum 3 08-09-2003 03:04 PM
