Quantcast headlights not working - how to disable DRL? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > headlights not working - how to disable DRL?
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
Old 05-19-2009, 07:35 PM   #1
Vladimer
Hey guys
My low beams have stopped working but i have all other lights working including my high beams, i checked all the fuses and they all look to be working as well. I was searching the forum and i came across a post that said that if your day time running light module has died you will get high beams only, no low beams. I really dont have the cash to replace that at the moment since anything that says 'module' is usually not cheap =/ My other car the DRL are a little relay looking box that you just unplug. Is the Jeep the same thing or do i have to buy a new module. And is there anything else that i could be missing here as well?
Summary
parking lights, high beams, turn signals all work,
low beams do not work
Thanks guys
Vladimer is offline   Reply With Quote
Old 05-19-2009, 07:39 PM   #2
RnEmOvr
Never Forget
RnEmOvr's Avatar
have you tried the e-brake trick? pull the e-brake 1 notch (wont be enough to engage brake) but on most cars it disables the DRL
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 05-19-2009, 07:57 PM   #3
Vladimer
I've tried it with the ebrake fully engaged since i was trying it in the garage and its 5 speed. No luck either
Old 05-19-2009, 08:43 PM   #4
RnEmOvr
Never Forget
RnEmOvr's Avatar
i have a wiring diagram on PDF file if you want it, wont tell you where its at but tells you how its wired
www.cityprofile.com
Old 05-19-2009, 11:04 PM   #5
Vladimer
thanks for the offer but if i looked at an actual schematic i probably couldn't tell ya left from right =/
Old 07-01-2009, 09:51 PM   #6
katu01
Same thing with low beams - turned them on this morning and both died right away. Hi beams OK, all other lights seem to work, but there is a slight flicker on remaining lighting. Is there a relay hidden in the fuse box that carries the current that the turn signal stalk can't because the fuse looks healthy? A burned out relay seems a better choice than a weekend threading a wiring harness or randomly replacing parts.
katu01 is offline   Reply With Quote
Old 07-04-2010, 07:41 PM   #7
katu01
Low beams mysterious death
Pop open the fuse box under the hood on the passenger side. Look for the encapsulated relay marked "headlights", pull it then reinsert. The headlights may work. If not, replace the relay. No mysteries. The fuse/relay box contains many encapsulated relays that if intermittently working or dead will save a fat repair bill.
Glock Forum
