Headlights Don't Work! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Headlights Don't Work!
All Bilstein shocks & struts - Lowest Prices Ever and TERAFLEX JK Speed bump kit AND limiting strap kit!! AT ROCRuffstuff Axle Simple Swap Kit!
Unread 04-16-2011, 08:39 AM   #1
Hilljack27
I was driving home and my headlights dimmed then went out completely. My turn signals, hazards, tail lights, and dome light still work. I went to a local auto store and they said that my headlights were not getting power. I have read numerous threads on this happening to other people but I am still unable to resolve this issue. I have: checked and cleaned the grounds, replaced the headlight switch, replaced the multi switch (Turn signal and brights), and checked the fuses in both boxes (behind glove box and under the hood). I was unable to find a fuse that was labeled "HEADLIGHTS" or something similar but none of the fuses were blown anyways. Is there something that I'm not doing or did I do something wrong?! Thanks for your input!
2000 TJ Sport
3" BDS Suspension Lift
1.25" JKS Body Lift
33" x 12.5" Mud Terrains
Aggressive style but a practical everyday driver.
Hilljack27 is offline   Reply With Quote Quick reply to this message
Unread 04-16-2011, 08:51 AM   #2
Davetopay
Bad relay?
Davetopay is offline   Reply With Quote Quick reply to this message
Unread 04-16-2011, 09:12 AM   #3
Hilljack27
ufortunately i'm not too familiar with the relay. Do you know where it is and how to tell if its bad?
2000 TJ Sport
1.25" JKS Body Lift
Unread 04-16-2011, 09:40 AM   #4
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
http://www.wranglerforum.com/f5/head...ble-28975.html
http://www.jeepforum.com/forum/f20/h...iagram-310906/
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 04-16-2011, 10:52 AM   #5
Hilljack27
Those diagrams make sense until I go look in my car and all i see are a web of wires. I'll try to switch out the relay once I'm able to find it. I saw one right underneath the steering column. Is that the one? Or where else could it be?
2000 TJ Sport
1.25" JKS Body Lift
Unread 04-16-2011, 11:32 AM   #6
Davetopay
Check the box with the maxi fuses and stuff under the hood.
Unread 04-16-2011, 11:59 AM   #7
Gary2
Its pretty common for TJs and XJs to have the headlight switch die , easy fix .
Gary2 is offline   Reply With Quote Quick reply to this message
