Headlights Don't Work! - JeepForum.com
post #1 of 7 Old 04-16-2011, 08:39 AM Thread Starter
Hilljack27
Hilljack27's Avatar
I was driving home and my headlights dimmed then went out completely. My turn signals, hazards, tail lights, and dome light still work. I went to a local auto store and they said that my headlights were not getting power. I have read numerous threads on this happening to other people but I am still unable to resolve this issue. I have: checked and cleaned the grounds, replaced the headlight switch, replaced the multi switch (Turn signal and brights), and checked the fuses in both boxes (behind glove box and under the hood). I was unable to find a fuse that was labeled "HEADLIGHTS" or something similar but none of the fuses were blown anyways. Is there something that I'm not doing or did I do something wrong?! Thanks for your input!
2000 TJ Sport
3" BDS Suspension Lift
1.25" JKS Body Lift
33" x 12.5" Mud Terrains
Aggressive style but a practical everyday driver.
Hilljack27 is offline
post #2 of 7 Old 04-16-2011, 08:51 AM
Davetopay
Bad relay?
Davetopay is offline
post #3 of 7 Old 04-16-2011, 09:12 AM Thread Starter
Hilljack27
Hilljack27's Avatar
ufortunately i'm not too familiar with the relay. Do you know where it is and how to tell if its bad?
2000 TJ Sport
1.25" JKS Body Lift
post #4 of 7 Old 04-16-2011, 09:40 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
TheBoogieman is offline
post #5 of 7 Old 04-16-2011, 10:52 AM Thread Starter
Hilljack27
Hilljack27's Avatar
Those diagrams make sense until I go look in my car and all i see are a web of wires. I'll try to switch out the relay once I'm able to find it. I saw one right underneath the steering column. Is that the one? Or where else could it be?
2000 TJ Sport
1.25" JKS Body Lift
post #6 of 7 Old 04-16-2011, 11:32 AM
Davetopay
Check the box with the maxi fuses and stuff under the hood.
post #7 of 7 Old 04-16-2011, 11:59 AM
Gary2
Its pretty common for TJs and XJs to have the headlight switch die , easy fix .
Gary2 is offline
Headlights Only Work With Highbeams- Please Help noselfcontrol TJ Wrangler Technical Forum 13 11-27-2009 09:30 AM
Need help - headlights don't work whiteguyjames TJ Wrangler Technical Forum 1 04-08-2009 09:37 AM
Headlights dont work bctj TJ Wrangler Technical Forum 10 10-26-2008 08:37 AM
Will these headlights work? Cchandler TJ Wrangler Technical Forum 6 05-15-2008 05:20 PM
Headlights won't work Big Brutal TJ Wrangler Technical Forum 1 11-24-2006 04:58 PM
