headlights acting weird - JeepForum.com
post #1 of 8 Old 02-25-2006, 08:38 PM Thread Starter
johnWJ
johnWJ's Avatar
2014 JK Wrangler
So I get in my jeep tonight to head home from work and I put on my right turn signal and it is acting kind of weird. It isn't blinking as brightly as it usually does and the ticking noise wasn't as loud. I didn't think much of it, but when Igot on my road, I turned my fog lights on for the hell of it. When I did, the light for my brights came on on the dash and the right turn signal light on the dash dimmed a little.
I pulled into my driveway to inspect it, and the front right turn signal blinks, but not as brightly. The drivers side headlight isn't shining as bright as the other. And when I turn on the fogs, they come on, and the one light gets even dimmer. ALso, when the headlights are on, the fogs are also on dimly, even though the switch isn't turned on.
Everything was fine last night. The only change has been that I took my winch off today. Any ideas, this is really bugging me.
2014 JKU
johnWJ is offline
post #2 of 8 Old 02-25-2006, 09:31 PM
1BadJeepX06
Taking your winch off may have caused you to lose a ground-wire connection somewhere.. These are the same symptoms my old 2500HD were giving me and it was a simple ground-wire that had giggled lose from it's connection in the engine bay..... Just gotta find out which one. When you do, it is a simple and easy fix...
Coming soon: 2000 Jeep Sport (modifications soon after) :-)
1BadJeepX06 is offline
post #3 of 8 Old 02-25-2006, 09:33 PM Thread Starter
johnWJ
johnWJ's Avatar
2014 JK Wrangler
I grounded the winch motor to the ground for the headlights. I had to unscrew that screw to get the motor ground back on. That was on the passanger side headlight.
2014 JKU
johnWJ is offline
post #4 of 8 Old 02-25-2006, 11:30 PM Thread Starter
johnWJ
johnWJ's Avatar
2014 JK Wrangler
OK from now on, I'm listening to JF guys. I went out and checked the wire I had loosned the nut on earlier, it was loose. Tightened it up and it works fine now. THanks.
2014 JKU
johnWJ is offline
post #5 of 8 Old 02-25-2006, 11:39 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
For anyone connecting a winch, never...ever... ground a winch like was done here. A winch can easily draw over 400 amps and the small gauge connections between the tub/chassis and the battery cannot support a load anywhere near that. A good strong winch pull can melt multiple ground connections as the winch searches for a good high-current connection to the negative battery post.
As winch installation instructions direct, always (always always!) connect both winch power leads directly to the battery!
Jerry Bransford is offline
post #6 of 8 Old 02-26-2006, 06:34 AM
James04TJ
James04TJ's Avatar
I had the same problem a while ago. The problem is always a ground issue. Normally pulling each headlight ground (screw holding a wire and lug just up and out from each headlight), cleaning it with some contact cleaner, adding some dialectric grease, and tightening it back up will fix the problem.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's)
James04TJ is offline
post #7 of 8 Old 02-26-2006, 08:57 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
x2 what is weird is an audio amp (some can pull as much if not more then a winch) need a ground a max of 3 feet never has made sence to me
RnEmOvr is offline
post #8 of 8 Old 02-26-2006, 04:17 PM Thread Starter
johnWJ
johnWJ's Avatar
2014 JK Wrangler
Damn...good thing I snapped a bolt on the install and never acutally had to use it. :
I guess I learned my lesson on that one.
2014 JKU
johnWJ is offline
Headlights - Acting like high beams? jonnyo JK Wrangler Technical Forum 59 11-06-2012 09:47 AM
4.0 Acting weird Redneck924 TJ Wrangler Technical Forum 7 02-27-2009 12:59 PM
YJ acting a little weird.... Tallanasty YJ Wrangler Technical Forum 2 02-12-2008 10:26 AM
Air Conditioning Acting Weird jwomack TJ Wrangler Technical Forum 7 06-29-2007 09:19 PM
My AC fan blower is acting weird... axia TJ Wrangler Technical Forum 2 02-14-2005 06:07 PM
