Headlight Won't Stay On - JeepForum.com
post #1 of 4 Old 09-26-2011, 12:11 AM Thread Starter
Line58
Over the last week I've been having some trouble with my Jeep's headlight not staying on. I'll pull the nob and the lights will come on, but sometimes after a few minutes they'll go back off but the marker lights will remain on. Sometimes jiggling the headlight nob will make them come back on. I suspect the problem is in the switch, but I'm not certain. How does one trouble shoot this kind of problem? Specific suggestions would be greatly appreciated as I know next to nothing about electronics.
Line58 is offline
post #2 of 4 Old 09-26-2011, 01:21 AM
troy.j
I would start with a simple inspection of the contacts at the switch. Clean and connect it again and see if it helped.
If it still doesn’t work, you will need to check the relay.
99 tj, 00 wj, 95 yj
...ask those who have bled of the cost of freedom and honor those who gave that others may have what we take for granted...
troy.j is offline
post #3 of 4 Old 10-02-2011, 12:27 PM Thread Starter
Line58
Things have since gotten worse. Originally I just had a hard time getting the headlights on, now the marker lights, the dash display, and the dome lights won't come on when the headlight switch is in the appropriate positions. The brake lights work when I depress the brake pedal and the dome light comes on when the door is open, so I know the wiring to them is good. I'm ganna swing by the local pick-n-pull and grab a switch off a Dodge Neon ('98 Dodge Neons and Jeep Cherokee headlight switches are the same part number as '98 TJs).
Line58 is offline
post #4 of 4 Old 10-02-2011, 02:35 PM
greenglazier
sounds like headlight switch needs to be replaced, i just had that same problem bought a mopar switch and problem solved. good luck with your fix
greenglazier is offline
stay with TJ, or go to WJ navy4life TJ Wrangler Technical Forum 8 08-04-2011 08:13 AM
Weber Rebuilt, won't stay stay running PrinothPro YJ Wrangler Technical Forum 8 02-20-2010 11:59 AM
Headlight stay on at night? Alang800 JK Wrangler Technical Forum 11 01-11-2010 01:32 PM
Engine lift to stay or not to stay Larry93 YJ Wrangler Technical Forum 4 09-21-2009 03:38 AM
should I stay away from these? Polaris TJ Wrangler Technical Forum 5 10-23-2005 04:16 PM
