Quantcast headlight upgrade? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > headlight upgrade?
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 01-19-2008, 09:07 PM   #1
V-8unlimited
headlight upgrade?
I am building a 2005 LJ unlimited from a frontend wreck. My queastin, I'm at the point now to put lights back in. I'm looking at the $129 dollar set from quadratec, but just curious how much brighter they can be, and if they are indeed worth the extra cash.
V-8unlimited is offline   Reply With Quote
Old 01-19-2008, 10:08 PM   #2
Recoil
Keyser Soze
Recoil's Avatar
I just replaced mine with a set of Sylvania Xtra brites cost me about 30 bucks for both and they just as bright though not as white as my buddys silverstars, to get to the point I dont think my headlight should or legaly could be any brighter than they are right now...the X-tra brights are great bang for the buck and im practically running people off the road with lights that cost me so little. So Id say no they arent worth it...save your money and invest in some high performance driving lights that you can actually use
Recoil is offline   Reply With Quote
Old 01-19-2008, 10:25 PM   #3
1CleanTJ
ipf housings with IPF X51 Fatboy Bulbs seems to work real well
1CleanTJ is offline   Reply With Quote
Old 01-19-2008, 11:13 PM   #4
badoosh27
i just bought some glass ones off of ebay for around $20. they seem a ton brighter than the sealed beams. just my .02
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts
[url]http://www.cardomain.com/ride/2634280[/url]
badoosh27 is offline   Reply With Quote
Old 01-19-2008, 11:22 PM   #5
tsc
IPF housing for sure- pick whatever bulb you want- get an after market wiring harness with relays that connect to the battery- IPF has one too.
tsc is offline   Reply With Quote
Old 01-19-2008, 11:31 PM   #6
Crashnburn80
x10
Get the IPF Fatboy bulbs with an H4 conversion and its sooo much better than stock.
http://www.northridge4x4.com/proddetail.php?prod=PKG-IPF
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75
and much more...
Riddler torture test video
Oil Filter Study
Useful Axle Info Thread
Crashnburn80 is offline   Reply With Quote
Old 01-19-2008, 11:42 PM   #7
JerseyDubbin
not trying to hijack but what is the brightest bulb you can put in the stock housing (01 TJ Sport).
JerseyDubbin is offline   Reply With Quote
Old 01-19-2008, 11:53 PM   #8
1CleanTJ
the stock headlights are sealed , meaning you need to replace the entire headlight to change it, Sylvania silverstar's are brighter then stock if you go that route
Old 01-20-2008, 12:09 AM   #9
Crashnburn80
If you convert to H4 then the 80w Fatboys are about as high as I would go on the stock wiring. Any higher and I would wire in a relay to take the load off the stock wiring. However, I wouldn't run anything higher than 80w as anything above 60w is illegal on the street.
Checkout this writeup to see the improvement:
http://www.4x4xplor.com/ipf-h4.html
and much more...
Oil Filter Study
Old 01-20-2008, 08:17 AM   #10
emschris
Oops, sounds expensive!
emschris's Avatar
I would read here first then decide.
http://danielsternlighting.com/
(81 CJ, 92 YJ, 97 TJ, All Gone) 05 TJ Rubicon
Stupity Kills, but not nearly enough.
emschris is offline   Reply With Quote
Old 01-20-2008, 08:40 AM   #11
Slithering_Joe
Hella H4 Conversions, European Code:
http://www.rallylights.com/hella/7in.asp
H6024A Two Lamps with Hella 60/55w H4 Bulbs (stock wattage) $82.00 incl. shipping
Read this too:
H6024C(*) Two Lamps with Hella 100/80w H4 Bulbs $89.00 incl. shipping
(*) Highly recommend upgraded wiring. Use a relay harness.
Hella H4 E-Code glass lamp housings:
Hella H4 E-Code low-beam pattern (80W):
Hella H4 E-code High-Beam Pattern (100W):
4.0L TJ 5.7L CTS 3.7L KJ
Slithering_Joe is offline   Reply With Quote
Old 01-20-2008, 09:00 AM   #12
knightsog
Concur on the Hellas. I got the Hella Vision Plus from Quatratec and I couldn't be happier. These were given the best reviews in the recent JP magazine test. Easy install except for those torx fasteners. What would normally take 20 minutes max for the whole job took me 1 hour just because of those little buggers. But I digress...
Well worth the coin.
2006 TJ "X"
1997 FLHTCUI
1980 MGB
FCC USN Retired
Yokosuka, Japan
knightsog is offline   Reply With Quote
Old 01-20-2008, 09:05 AM   #13
Whybu1
Go STEELERS!!!!
Whybu1's Avatar
I really like the European pattern lens as well. I have the 80/55W bulbs in mine. Only real issue is trying to read any tall signs at night as the cutoff is designed to keep the light low.
Whybu1 is offline   Reply With Quote
Old 01-20-2008, 09:57 AM   #14
daveshan
Feeding the money pit
daveshan's Avatar
I've been running Hella or Cibie lights for years in everything I've owned that would take them. You can't beat the beam pattern and can get them fairly reasonably on ebay. I paid ~$75 for H-4 housings and bulbs for my TJ, last year.
Dave Shannon
Durango, CO
'01 TJ Sahara
'98 XJ Sport
'00 XJ Wife's ride
Gone but not forgotten
'56CJ, '61 Wagon, '51 Pickup, '07 JK 4dr
daveshan is offline   Reply With Quote
Old 01-20-2008, 10:48 AM   #15
victory red
I have been running the silverstar sealed beam replacement's. with the silverstar bulb's in the fog's also. no complaint's. big improvement from stock.
2012 ARCTIC
IN SERVICE 12/17/11
victory red is offline   Reply With Quote
Glock Forum
