Quantcast Headlight out on 99 tj - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Headlight out on 99 tj
Old 03-10-2009, 06:58 PM   #1
nopa
The other day i noticed after a little light wheeling out to my camp...nothing rough just rutted up logging roads and dirt secondary roads to get there that my passengers side headlight was out now ive only had my TJ for a little over 8 months and this is my first headlight issue.. do i have to replace the entire fixture or just the bulb like normal vehicles i havent been able to get out to look at it due to the weather the past two days... any help is appreciated..
Originally Posted by RedJeepXJ View Post
what the ****????????, that has to be one of the most untrue statements ever made on jeepforum
nopa is offline   Reply With Quote
Old 03-10-2009, 06:59 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
It uses a 7" sealed beam headlight just like a car uses, it has no separately replaceable bulb.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 03-10-2009, 06:59 PM   #3
Cchandler
It's most likely the entire housing if it's stock. My guess is it's stock so it's the entire housing and everything. They're cheap at autozone I get them for $9.89.
Cchandler is offline   Reply With Quote
Old 03-10-2009, 07:07 PM   #4
nopa
alright thanks for the quick responses... how hard is this gonna be as i have a pretty decent toolset at my college house but no garage or anything to work on it in so are we talking like a ten minute swap or an hour project.... hopefully the former as its been rainy and about 35* here in good old NW PA ha
Old 03-10-2009, 07:14 PM   #5
Jerry Bransford
Swapping a sealed beam headlight is easy though you'll need a screwdriver-like tool with a T-15 torx tip on the end to get the shiney outer trim bezel and retainer ring off that holds the actual headlight in place. Be careful to look closely once you get the shiney bezel off so you don't try to turn the wrong torx-head screws to remove the headlight. There are two torx-head adjustment screws diagonally across from each other on either side of the headlight that are used to aim the headlight and you don't want to turn them.
Only remove the three screws that hold the retainer ring in place (different from the outer shiney trim bezel) that holds the sealed beam headlight. Once that retainer ring is removed, the headlight can be lifted out and unplugged. Should take you no more than 10 minutes start to finish. When you buy the replacement headlight, buy a screwdriver style torx-head that fits the torx screws used on the headlight assembly which is the style needed to remove the headlight. Torx sets like fit onto wrenches are too short and they won't work.
Getting Savvy...
Old 03-10-2009, 07:14 PM   #6
Cchandler
You are going to need a Torx T-15 bit and thats it. It will take like 10 minutes because I just got my tools out and went outside and took it apart to make sure the bezel screw and the housing screw were the same size. I couldn't remember.
Old 03-10-2009, 07:18 PM   #7
nopa
thanks alot guys... as a poor college student i dont have the extra money to go messing up simple things like this... i appreciated it sooo much...
thanks guys !
Old 03-10-2009, 07:28 PM   #8
Best4x4
Best4x4's Avatar
Before replacing it double check the connector at the back of the headlight. I've had mine loose a good connection (the stock wiring is rather pathetic on mine with bare wire showing for at least 5MM before the actual plastic connector on two of the wires) Just take it off, bend the pins on your headlight out a bit and re-connect it and see if it works. If it doesn't then it is indeed bad. I'm going to rewire mine soon with some high temp replacements and wire it up correctly vs how the guys at the factory did it!
05 Rubicon with a 4spd Auto, Banks CAI, Optima Yellow Top Battery, Mastercraft Rubicon Suspension Seats, MT Classic II Beadlock Rims with 33 Pro Comp M/T's, Rugged Ridge XHD Front Bumper, Rugged Ridge Rear Tire Carrier/Bumper, Warn Gas Tank Skid, GenRight Front Tube Fenders, Pro Comp 2.5inch Coil Springs, OME Shocks, JKS 1.25 BL, JKS 1inch MML, Warn XD9000i Winch with Warn Wireless Remote, Cobra CB with a 3ft Firestik Antenna, 48inch Hi-Lift X-TREME Jack, and all the survival gear needed for owning a Jeep.
Best4x4 is offline   Reply With Quote
Glock Forum
