Headlight Help!!! - JeepForum.com
post #1 of 3 Old 03-26-2010, 11:24 PM Thread Starter
Wildcat83
Headlight Help!!!
So I just replaced my headlights with some Silverstars, and like a moron I thought I had to adjust them. There are 3 adjusting screws for each headlight, 2 on one side which appear to be up and down/side to side, and one on the other side which appears to adjust up and down as well. I started adjusting them and now I got everything so out of whack I can't get the chrome bezel on because there is so much of a gap on one side or the other. Just when I think I got it adjusted right, I try to put the bezel on but it wont fit, plus it looks like the light is ****ed really bad in the socket. Does anyone know the trick to this? It looks like there are 2 screws that adjust the same direction, but do I have to adjust both of them a little at a time or just one? I need to totally start from scratch it seems but I have no idea what to do here.....
Wildcat83 is offline
post #2 of 3 Old 03-26-2010, 11:56 PM
GREASEMONKEY
Here's a post with a few links.
http://www.jeepforum.com/forum/f9/tj...tments-626853/
Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings.
GREASEMONKEY is offline
post #3 of 3 Old 03-27-2010, 12:49 PM
BlueFlame
BlueFlame's Avatar
Not again...
There's only 2 adjustment screws. They are the ones behind the 2 notches in the bezel.
That 3rd one you messed with isn't an adjustment screw.
and you weren't a moron, you always need to re aim headlights when you replace one, and almost always even when you only replace an H4 bulb.
BlueFlame is offline
only one headlight UNCLEBRO TJ Wrangler Technical Forum 13 07-13-2013 09:58 AM
help with headlight bdhawk TJ Wrangler Technical Forum 2 11-10-2009 01:34 PM
Headlight out on 99 tj nopa TJ Wrangler Technical Forum 7 03-10-2009 06:28 PM
Headlight kit libertynewyork TJ Wrangler Technical Forum 32 10-20-2007 09:09 PM
Headlight ON then OFF JeepDrivr93 YJ Wrangler Technical Forum 4 10-17-2004 11:27 AM
