hd steering linkage? - JeepForum.com
post #1 of 9 Old 12-09-2010, 12:30 PM Thread Starter
animaltj
Why cant I take grade 8 5/8 hardware , drill out my knuckle 5/8, DOM tubing, bung inserts and 3/4 heim joints build my own steering linkage for my TJ ( Rubi D-44)?
I dont care about street legal! this is no mall crawler its a trailer queen.
All of aftermarket is so exspensive. Any thought on why this will not work is appreciated? thanks.
animaltj is offline
post #2 of 9 Old 12-09-2010, 12:32 PM
NotURMailman
NotURMailman's Avatar
You could. Are you planning a crossover system, or would ou be welding tabs to the draglink for the tie rod? If you do a cross over you'll have to rework your track bar to avoid severe bump steer.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is online now
post #3 of 9 Old 12-09-2010, 01:55 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You will wonder how they do it so cheap when you get done if you use the appropriate quality parts.
Ends are 50 bucks each for anything worth throwing under there. You will need 6 of them because you will need to re-do the trackbar at the same time.
Weld in bungs are 15 each.
Jam nuts and hardware are another 30 bucks and you still need tubing. 3 foot for a draglink and 9 feet for the tie rod and trackbar. That's 11 feet at about 10 bucks a foot minimum.
So far you're up over 500 bucks and you haven't even started cutting and welding yet.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #4 of 9 Old 12-09-2010, 04:02 PM
Recoil
Recoil's Avatar
1988 MJ Comanche
It's expensive as mrblain said. Not to mention the R&D that has gone into making sure the geometry is correct. Not to mention if you make a mistake and have to start over on something. I'm sure it would be a great learning experience but it'll cost ya.
Recoil is offline
post #5 of 9 Old 12-10-2010, 07:54 AM Thread Starter
animaltj
Thanks everyone for input. Mr. Blaine here is where Im at now:
bungs-3/4-6.25x 4=25.00 free shippping
misalingment spacers reducing 3/4 to 5/8- 4x 8.00= 32.00 free shippping
chrome moly heim joints rated 26,061 lbs- 4x9.00= 36.00 free shippping
dom 1.25 x .120 wall- 5.53 a ft- 11x 5.53= 60.83 pick up no shipping
grand total =153.83 my labor fabing and such free
So what do I have to do with my track bar?
Its adjustable and has been lowered from stock to compensate for alignment with drag link and dropped pitman arm. 6 inchs of suspension lift. So I currently have no bump steer.
Thanks again for all replies!
animaltj is offline
post #6 of 9 Old 12-10-2010, 08:10 AM Thread Starter
animaltj
I forgot to add crossover is the way I am going with 5/8 18-8 stainless bolts.
animaltj is offline
post #7 of 9 Old 12-10-2010, 02:13 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If you plan on drilling the knuckles and clamping a rod end ball direct to the knuckle, it would be in your best interest not to. The iron in the knuckle is too soft and will let the small surface area of the edge of the ball sink into the iron as you use the steering. Then the bolt will loosen up and the hole will wallow out and if you don't catch it in time, it will ruin the knuckle.
I am Savvy
mrblaine is offline
post #8 of 9 Old 12-10-2010, 02:25 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You missed the 10.00 bucks a foot on the tube because you've haven't yet realized that .120 isn't thick enough for steering. That means you will have to sleeve it with at least 1" x .188 wall in Dom or .120 in chrome moly. That doubles the price.
3/4-16 isn't typically robust enough for a tie rod. I only use 7/8-14 rod ends with 3/4" balls because the larger shanks increase the bearing surface area around the ball and make them last much longer, or long enough that we've never worn them out. On the other hand, we can take out the smaller ones in a couple of trips.
Those prices look like Midwest Control stuff. Were I you, I'd order one and check the fit and quality before I invested in the whole mess.
As far as 9 bucks for a 3/4" rod end? Try one before you buy the rest because I'll bet a fair bit they have the tolerances of a tractor link.
I am Savvy
mrblaine is offline
post #9 of 9 Old 12-10-2010, 02:26 PM
Steve98
Would some grade 8 washers under the rod ends fix that?
2006 LJ Rubicon
Steve98 is offline
steering linkage kit mario figueroa YJ Wrangler Technical Forum 2 02-24-2010 08:21 PM
Steering Linkage - Which One? melcrim TJ Wrangler Technical Forum 3 01-25-2010 03:10 PM
steering linkage MCanavan TJ Wrangler Technical Forum 1 05-07-2006 11:15 AM
lubricating steering linkage, steering and suspension ball joints? losfreddy TJ Wrangler Technical Forum 4 03-14-2006 04:39 PM
Steering linkage... HELP!!! Trucidus Sum YJ Wrangler Technical Forum 1 04-26-2002 08:58 PM
