-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   HD Front LCA Bracket too large for Cam Bolt (http://www.jeepforum.com/forum/f9/hd-front-lca-bracket-too-large-cam-bolt-1758970/)
justinkau 11-04-2013 08:40 PM
2 Attachment(s)
Hey Guys,
I am replacing my front lower control arm brackets and the hole for the cam bolt looks like the wrong diameter.
The cam bolts I got from napa look like 9/16th and seem to match my stock ones fairly well.
But the HD LCA bracket hole looks too big.
Here some measurements in mm.
cam bolt diameter 13.78mm
cam bolt diameter from flat 10.61mm
LCA bracket diameter 16mm
So if i had the cam bolt centered(like how it was before i removed the bracket)
I would have a gap of 16mm-10.61mm = 5.4 mm
that seems like a lot of wiggle room up and down?
Thanks,
Justin
Unlimited04 11-05-2013 05:30 AM
you haven't filled out your profile.....maybe do that so we can help you?
is there any reason you need cam bolts? do you not have adjustable lower control arms?
finally, as long as you torque the bolt to spec and keep the surface of washers on "land", you'll be fine.
mrblaine 11-05-2013 06:42 AM
Whether or not that slot will work with the extra width that it has depends on the control arm he is using. I don't know that I would be comfortable using that with JJ's even though they have more surface area at the end the bolt sleeves.
I wouldn't use them, not enough area to get proper clamping and some arms the bolt sleeve would just about fit right through that slot.
justinkau 11-06-2013 12:07 AM
sorry I have a 1999 TJ with a 4" short fixed arm procomp kit. I just need a quick fix to get back down a washboard road to the beach. No more wheeling. I was thinking i could weld a bead down the top flat section of the oblong cam hole. But is that overkill? On my stock lca bracket I had a fixed centered washer and the fit was much tighter top to bottom.
J03_TJ 11-06-2013 06:47 AM
368 Attachment(s)
Can you contact the company that that made those brackets and see if they make any for a TJ?
justinkau 11-06-2013 10:49 AM
Yeah I contacted the seller and he said thats how they are supposed to be
aparke4 11-06-2013 10:55 AM
Are we sure those are not for the rear uppers?
rchase559 11-06-2013 11:42 AM
Not only do the uppers have a smaller bolt and mounting width than the lowers, none of the mounts look even close to that.
cmecha 11-06-2013 12:07 PM
just buy LCA mounts from Iron rock offroad no need for cam bolts.
mrblaine 11-06-2013 12:14 PM
The seller is very mistaken in that assessment.
cmecha 11-06-2013 01:25 PM
also i'd listen to Mrblaine and unlimited04 they know what they are talking about.
mudb8 11-06-2013 02:03 PM
Sure if they were made to use with 18mm ford superduty bushings.
The pro comp bushing sleave will likely take the shape of the slotted hole and pinch the cold cut ring.
mudb8 11-06-2013 02:17 PM
I personally would want the cams for a 4" lift using stock uppers and 16" fixed lowers to get the caster closer to 5 or more. The smaller the tire is the more it matters. It may be "a jeep", i want them to drive like a car.
cmecha 11-06-2013 02:42 PM
I have an 06 and mine didn't even come with caster bolts
mudb8 11-06-2013 03:36 PM
none do. provisions to use them are there from the factory.
moog part # K100047
specialty products part#SPP * 82380
The time now is 09:16 AM.
