hazard lights switch/relay - JeepForum.com
post #1 of 1 Old 12-03-2009, 10:52 PM Thread Starter
Ksellers11
So my starter gave way on me in a parking lot today, causing me to have to bump start the jeep. While doing this, i turned on the hazards... Once the jeep was started, i tried to shut off the hazards, but the right blinkers stayed on. I hit the button again, and all 4 lights started flashing again. I'm assuming these two problems are not related and this was only discovered by coincidence (this is the first time i have used the flashers in quite some time), and i have already replaced the starter and the jeep starts fine. does this sound like a faulty switch, or a relay or fuse? has anybody experienced this? any help would be appreciated
edit, i should have added that the only way to stop the lights from flashing is to disconnect the battery
Ksellers11 is offline
hazard lights not working Dom45ACP TJ Wrangler Technical Forum 9 07-27-2014 12:08 PM
!!turn signal/hazard warning switch!! ado2987 YJ Wrangler Technical Forum 10 04-29-2009 08:33 PM
Hazard Light Switch 66vette TJ Wrangler Technical Forum 2 11-22-2008 10:46 AM
Hazard Lights? Need Help.. btn2020 YJ Wrangler Technical Forum 8 03-05-2008 07:33 PM
Tail lights not working ( hbl, switch, fuse and relay) JESSETHELJ TJ Wrangler Technical Forum 1 09-03-2006 01:48 AM
