Havoline or rotella may switch - JeepForum.com
post #1 of 12 Old 01-27-2014, 09:34 PM Thread Starter
mustang67ford
In my 05 rubicon with 4.0, I have been running havoline 10w30 regular oil. I actually only have like 28,000 miles on the jeep (don't run it here in the PA winters). Anyways, when I switched to this oil, it seemed like a popular one at the time. Now, I recently purchased a 99GC with 4.0 as well with 117,000 miles. From what i read on the GC forum, I am thinking of running rotella 10w30 oil non-synthetic. I would like to run the same oil in both jeeps so I was thinking of switching the ruby over to 10w30. Any thoughts?
I also have a sludge problem in my GC which I am going to try to address with marvel mistry oil.
mustang67ford is offline
post #2 of 12 Old 01-28-2014, 02:38 PM
sunsetclb
I use rotella in everything, have for years. No issues that I can tell.
sunsetclb is offline
post #3 of 12 Old 01-28-2014, 02:46 PM
ChrisHager
Administrator
ChrisHager's Avatar
Rotella has a stout add pack that the 4.0 likes (high ZDDP content). It also cleans very well which will be helpful for the sludge issue in the WJ. I'd say go for it for the TJ.
FWIW, I use Rotella T5 10W-30 in my 4.0 WJ, 2.5 TJ, and 5.9 J-10.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is online now
post #4 of 12 Old 01-28-2014, 02:48 PM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
Isn't Rotella that hazelnut spread stuff? Oh,that's Nutella.
TheBoogieman is offline
post #5 of 12 Old 01-28-2014, 03:42 PM
77351wcj5
Yep. That is actually some pretty good stuff.
77351wcj5 is offline
post #6 of 12 Old 01-29-2014, 10:15 AM Thread Starter
mustang67ford
Thanks, I picked up the 10W30 for the GC. Not the synthetic, just the regular.
post #7 of 12 Old 01-29-2014, 11:10 AM
Robert J. yates
FWIW... Shell reduced the additive package in Rotella some time ago. If you really want a high ZDDP oil, go for something like Amsoil Z-Rod and some of the other specialty manufacturers.
http://www.amsoil.com/shop/by-produc...tic-motor-oil/
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #8 of 12 Old 01-29-2014, 11:19 AM
ChrisHager
Administrator
ChrisHager's Avatar
When did they lower it? Just curious. It appears it still has quite a bit...
2010 VOA:
Phosphorus..976..975
Zinc........1189..1197
I found a UOA from 4/13 for a Dodge Caliber that had Phosphorus between 750 and 1000, Zinc between 850 and 1200.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #9 of 12 Old 01-29-2014, 12:13 PM
Robert J. yates
The issue with high ZDDP packages is that it not only impacts catalytic converter but DPF's as well (soot/ash formation) so the diesel oils have seen reduced packages much in the same way regular oils have. I used to run T5 when I first built my motor and switched over to Z-rod since it is specifically designed to deal with flat tappet cams. A couple of VOA's for comparison. T5 is OK and probably plenty fine for a stock 4.0.
post #10 of 12 Old 01-29-2014, 12:45 PM
ChrisHager
Administrator
ChrisHager's Avatar
Awesome! Thanks for the VOA's! Amsoil sure does have more than Rotella. I know ZDDP does affect catalytic converters. I view it as a cheaper expense compared to new lifters/camshaft though.
I switched to T5 after having a lifter failure around 87k that cost me a weekend of work and about $700. I had records showing that the PO had regular oil changes done by the dealer. Ironically, I later found out the dealer changed a lifter (not plural) for the PO at 66k (and a 242 at 80k??). Most likely, they didn't pull the camshaft and inspect the lobes. My 87k failure was probably due to Jeep's cheap fix (thanks, Jeep ).
That being said, why the failure at 66k? I have heard a time or two about these 4.0s eating lifters but it makes you wonder if these failures are due to inadequate amounts of ZDDP in oil.
Here are a couple pictures of the carnage. The camera wasn't being kind that day but you get the point.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #11 of 12 Old 01-29-2014, 01:52 PM
mike_dippert
mike_dippert's Avatar
I tried all sorts of additives to help my lifter tick. None (including MMO) worked. I used M1 5-40 for 6k miles, then found Rotella T6 on Amazon cheaper so I'm using that now. The tick is better, but not gone.
mike_dippert is offline
post #12 of 12 Old 01-31-2014, 09:30 PM
TJJP77
TJJP77's Avatar
I run Valvoline VR-1 10W-30 non-synthetic. Engine is the quietest it's ever been when using this oil. ZDDP only really impacts the catalytic converter if you are burning oil - remember that catalytic converters have been around since 1975 and ZDDP in oil wasn't really reduced until the late 1990's/early 2000's. I know plenty of people that had 90's cars with 200K+ mile on them on the original converter.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
