Having trouble starting my jeep? - JeepForum.com
post #1 of 12 Old 08-25-2010, 11:20 AM Thread Starter
AZAZEL1313
I'm having some trouble starting my jeep. whats happining is when I first try to start it I have to keep it cranking for a while then it will start to sputter for a bit, then level off. once its running it is fine and will start back up fine as long as it with in a few minutes off shuting it down. I also noticed a strong smell of gas when I first start it, and if I turn the key on and off 4-5 times alowing the fuel pump to run each time it will start right up but I still get the fuel smell. I've looked around and cant see any leakage around the lines or throttle body and the smell seems to be from the front. any ideas?
AZAZEL1313 is offline
post #2 of 12 Old 08-26-2010, 08:44 AM
blubaru2002
Are you pumping the gas pedal when you are cranking the motor? That would cause the gas smell. Check your battery terminals. If they are loose or corroded then you need to replace them. That is what fixed my problem.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #3 of 12 Old 08-26-2010, 09:17 AM
NorthWhiteWolf
my does it to but i just got used to having to "try" starting 2 times before it start (mechanic says it's a "jeep thing") but i will also try replacing the battery terminals them selvs. (just put new battery in)
"would rather build then buy" - My Grand Father Francis ( a true " red-neck inventor")
NorthWhiteWolf is offline
post #4 of 12 Old 08-26-2010, 09:22 AM
madmilitia
same thing happens to mine but i don't have gas smell that i notice, i replaced my fuel pump but didn't replace the fuel presure regulator which has an anti leak back mechinisim.
so i gotta do that but i can't find the part lol
RJC #600
colorado jeep club #269
Don't grammer cop me, if you can't understand what i'm trying to say it's you not me that needs to change.
madmilitia is offline
post #5 of 12 Old 08-26-2010, 06:55 PM Thread Starter
AZAZEL1313
I'm not pumping the gas peddle at all. never even considered the posibility of corroded terminals though. it'll be nice if its something simple like that. I'll have to check them out tomorrow. thanks..
post #6 of 12 Old 09-07-2010, 12:05 PM
Rafikie
stuck injector or pressure regulator
2000 TJ WW build in progress
RIP: 97 TJ juggy
WM4x4
Rafikie is offline
post #7 of 12 Old 09-07-2010, 12:33 PM
69injun
Pressure regulator, just replace the one in my oldest son's Grand Cherokee. Fixed it right up.
Kevin
97 TJ on 37's and 69 Firebird Convertable on blocks
69injun is offline
post #8 of 12 Old 09-07-2010, 12:33 PM
Wrangler_91
I had a similiar problem about 6 month ago. I checked EVERYTHING and it ended up being the MAP sensor. Once I replaced that it started up without an issue. My problem got progressively worse as time went on. It got to the point that I had to crank a lot more than I should to get to to fire just once, then it would start to sputter and sputter, then once it got running it was fine. Just a thought.
Wrangler_91 is offline
post #9 of 12 Old 09-08-2010, 08:38 AM Thread Starter
AZAZEL1313
Thanks for the tips.... I'll pick away at these and see if I can't narrow it down!
post #10 of 12 Old 09-08-2010, 08:44 AM
mdm
Farm Wheeler
Are you pumping the gas pedal when you are cranking the motor? That would cause the gas smell. ...
How does pumping the pedal cause this on our computer controlled fuel injected engines? He doesn't have a carburetor with an accelerator pump.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #11 of 12 Old 09-08-2010, 09:18 AM
Redryan98
+1. I have same issues. Haven't had a chance to fix but have done a lot of research on it. If you smell the gas at startup I would think it might be leaking injector. From what I have read, if it starts right up and runs fine after a lot of cranking it is more likely the pressure regulator. If it sputters/smells than it is likely injector as the excess gas that leaked is being burned off. Some have suggested running jeep, turning off, waiting a while, than pulling plugs to see if any of them smell like gas. Good luck
Redryan98 is offline
post #12 of 12 Old 11-12-2013, 02:49 AM
ablopa45
1998 FSJ Cherokee
Hey Try to change the fuel pump
ablopa45 is offline
fuel pump , starter , starting , tj , wrangler
Jeep starting trouble 93jeepREDSOX YJ Wrangler Technical Forum 8 03-20-2017 05:41 AM
Jeep has trouble starting dmico76 TJ Wrangler Technical Forum 3 08-22-2009 07:37 PM
95 jeep trouble starting meanstreak02 YJ Wrangler Technical Forum 2 10-27-2008 10:11 AM
Trouble Starting Jeep Snowman01TJ TJ Wrangler Technical Forum 2 09-18-2004 03:40 PM
Jeep has trouble starting GLADIATORTJ TJ Wrangler Technical Forum 2 06-24-2004 12:04 PM
