Having some trouble with engine - JeepForum.com
post #1 of 7 Old 09-04-2006, 12:12 PM Thread Starter
godsowndrnk
Junior Member
So yesterday we took the Jeep to my family reunion, about 30 miles away. Ran fine the whole way, until we got off the interstate. It started running really rough, wanting to stall, and backfiring. We let it set for a few minutes, started it up, and it was fine. Then last night we went to a friends house. Took the interstate with no problems. Exited, and as soon as we started into town, same thing. Smelled strong gas odors, backfiring, and wanting to stall. Again, turned it off for a minute, started it back up, and it ran fine. I made an intake with an old K&N, and some p.v.c. Could the new air flow be affecting the computer? It only happens when we go from interstate speeds, down to city speeds. If I start off in town, and stay around here, it doesn't happen. Plus the fact that when I turn it off, and restart it, it works fine again. Almost like it's resetting itself. Ideas please. Thanks.
godsowndrnk is offline
post #2 of 7 Old 09-04-2006, 12:31 PM
Conundrum
Conundrum's Avatar
Doubt the intake has anything to do with it. Might be a sensor issue. Any codes?
Matt
2001 Jeep Wrangler Sport 4.0L - Amber Fire Pearl Coat
1981 DeLorean DMC-12 VIN: 2953
Conundrum is offline
post #3 of 7 Old 09-04-2006, 12:37 PM Thread Starter
godsowndrnk
Junior Member
if there were codes, they would come up on the odometer screen, right? If so, I didn't see any. I'm going to pick it up in a few minutes, and drive it back home the same way I took it in. Hopefully it will act up again, and I can look for codes.
post #4 of 7 Old 09-04-2006, 12:46 PM
Conundrum
Conundrum's Avatar
I think to see if you have any codes on yours, you have to turn the key on and off three times. On the third time on, leave it on and it will display if there are any.
Matt
post #5 of 7 Old 09-04-2006, 12:49 PM
redvett94
If there are codes the SES light will be on. Not always does the SES go on and there most likely be a basic problem like coolant, airfilter, fuel or many more simple things that could be wrong.
2000 Sport.
redvett94 is offline
post #6 of 7 Old 09-04-2006, 01:57 PM Thread Starter
godsowndrnk
Junior Member
Just drove it back home. It is worse today than yesterday. I actually had to pull over because it wouldn't run. The "Check Engine" light is now on too. How exactly do I check for codes?
ok, i just tried the on off on off on thing, and it didn't give me any codes. any other ideas? other than a garage?
post #7 of 7 Old 09-04-2006, 03:55 PM
Rule303
Buy a code reader or go to a parts store that will do it for you.
Rule303 is offline
engine trouble greenmachine99 TJ Wrangler Technical Forum 7 01-03-2007 02:40 PM
Engine trouble aju4 TJ Wrangler Technical Forum 3 07-19-2005 08:05 PM
Engine trouble, PLEASE HELP Blackhole TJ Wrangler Technical Forum 5 07-12-2005 08:37 PM
Engine trouble... sgrim80 YJ Wrangler Technical Forum 4 02-04-2005 01:33 PM
Engine Trouble, Help Please? JSBlu974X4 TJ Wrangler Technical Forum 5 02-07-2004 08:11 PM
