Having A Hard Time Getting Into 2nd Gear From 1st Gear
#1 | |
Hi,
I am a proud new Jeep owner - I bought a 98 TJ Sahara model that is a 5 speed. It has about 82K miles, so I am assuming my clutch may be going, but I know people who have had jeeps for 120K miles with no clutch repair. Every gear is working well except when I go from 1st to 2nd, every second or third time that I shift into 2nd, I have trouble getting it to go in. It's not grinding, but I have to leave the clutch in and force it into gear. Has anyone had a similar problem? If it is going to take a full clutch repair, does anyone know what these run? Thanks! Jill
#2 |
I dont know if I can help but I have a brand new 05 Jeep Wrangler and 2nd gear is a little tougher to get into than all the others. I was wondering the same thing myself. Just so you know you are not alone! Good Luck!
[FONT=Impact]2005 TJ 4.0 Manual 6 Speed[/FONT][SIZE=2][/SIZE] [FONT=Impact][COLOR=Red]FLAME RED[/COLOR][/FONT][SIZE=2][/SIZE] [FONT=Impact][SIZE=1]Clarion DXZ845 / Sony XE-744 / Garmin GPSMap 60CS W/ Mount / Kargo Master Congo Cage / Yakima 58" Crossbars / Lowrider Towers / Loadwarrior Basket / Jeeperman 54P Winchready Front Bumper / Jeeperman TJ Swingaway Rear Bumper / Jeeperman Diamondplate Trail Skids / Rubicon MOAB Alloys / 31" MT/R's / RE 2" BB / [/SIZE][/FONT][FONT="Impact"][SIZE="1"]Tuffy Overhead Security Console w/ Uniden PC78LTW CB Radio[/SIZE][/FONT][FONT="Impact"][SIZE="1"] / Midland 75-822 Handlheld CB Tranceiver[/SIZE][/FONT][FONT="Impact"][SIZE="1"] / Ultimate Air Multi Force 10 XT Series Air System [/SIZE][/FONT] |
#3 |
Not sure what the weather is like were you are from....but there are two shifter boots on your 5 speed a lower one and an upper one (you cant see the lower one) and they tend to be a little stiff on the shifter rod esp in the cold weather they like to freeze up. Some people cut the lower one because you cant see that one to loosen it up a lil bit. Mine does the same thing but only in the cold. If it does it all the time it might be a syncronizer. My buddys went out in his mustang and if you dont shift at perfect RPM's it would grind a lil. As for a full on clutch rebuild i dont think that will be your issue. A lot of people run big tires with 200,000 miles without a clutch problem (I have 35's and 152,000 mi) but just for prices my S-10 clutch was $100 with lifetime warranty, but i did all the work myself. The local shop wanted $400 dollars (with parts and labor), and another guy wanted $300 (with parts and labor). Labor is alot because you have to drop the Tranny. I hope this helps ya out a little bit.
'97 Tj Sport, 4.6L Stroker, 5-Speed, 4-in suspension lift, 35" TrXus M/t's, Dana30/Ford 8.8 w/ Aussie Locker, Teraflex ExtremeShort SYE, custom front and rear bumpers, Flowmaster Off-road Series, and a bunch of other goodies........MoPar or No-Car!!! |
#4 | |
Never Forget
not the clutch, i had the same prob so i replaced my clutch and it still does it, so when you find out please let me know, also my boot is removed due to bl, and i forgot to put lower one back on and still did it, dealership was cheapest place for clutch kit
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers Quote:
www.cityprofile.com |
#5 |
They cheapest clutch i found for my S-10 was AutoZone....so check there to if you think that will be the problem. Make sure you shop around though cuz there was over 100 dollar difference in some when i went lookin
#6 |
Ive heard about this from alot of people, 1st to 2nd seems to be my easiest shift too. Its most likely not your clutch goin out. I would try to come in at some other angles. On my previous truck the shifter was a piece of crap and it would have problems goin into any gear. I just had to learn the sweet spots after awhile, so maybe you gotta do the same. Good Luck
'97 TJ Sport....I take care of her and she takes care of me -3" Full Traction -33" Kumho MT -Black Steelies -Custom Fabbed Front Bumper -Herculined Tub Comin soon-4.10's, 1" BL/MML, Skids |
#7 |
Jill,
Your '98 Sahara has an AX-15 transmission. They are well noted for being somewhat notchy when shifting from 1st to 2nd gear. I have a '98 Sahara....I've lived with it since day #1. I doubt it is your clutch....it if were, you would be having issues getting into all gears....the clutch doesn't discrimiate when it comes to shifting. The comments about the inner shift boot is valid and can often times improve the situation. Try it. If that doesn't get you the results you want, change the fluid in your transmission. You want to replace it with Redline MT-90. If you can not find it at a local parts store (usually a hot rod or speed shop will carry it), then order it from Summit Racing on-line. It is MUCH better than the factory fluid (hard to even say if yours has been changed) and will also help improve the 1st to 2nd shift issue with the AX-15 tranny. Your tranny takes 3.25 quarts of fluid, so pick up 4 quarts. Good luck! |
#8 |
What about royal purple, how would that compare to redline?
#9 | |
If you shift slowly when it is still cold it doesn't make any noise but if you force it you can hear the synchro's engage with a clunk/grind sound. Kind of annoying but I think it is a "feature" of the 6-speed tranny.
2005 Impact Orange Rubicon 6 speed standard 4.0L I6 engine Mechanical Engineer behind the wheel Toronto, ON, Canada |
#10 | ||
-Shayan A.K.A: Sean Quote:
#11 |
Ditto what Stu said, dont try to "fix" it because you'll only spend $ and get aggravated. MT90 helps, but as the outside temps drop, you'll still notice it more than warmer days. And just to cheer you up, something else you'll notice as it gets colder, the OEM radiators tend to leak more.......
98 TJ 4.0L | GenRight Stretch, 4 Link | Built XJ HP30 & XJ 44 | AW4 | ARB's | 35" Krawlers | Allied Beadlocks | York OBA | Warn 9500i etc. | M416 Trailer Kentucky Krawlers |
#12 |
goodluck working out the hardware issues..until then...
try pausing for a second in your shift between 1st and 2nd. push the clutch in. Move the stick to N (keep holding the clutch OR relase for a moment and push it back down). Give the RPM's time to fall (usually about 1-2 seconds during normal take-off).then move the stick to 2nd and complete your shift. hope that makes sense...and helps a bit.
Colorado Jeep Club Member # 315 |
#13 |
I am having the same problem. I am running an expensive amsoil synthetic in my manual transmission. Is this MT-90 that much better? Would it be worth it?
Why would thicker oil be a problem? I figure it would coat the gears better. |
#14 |
Generation Dead
Put synthetic 10w-30 motor oil in it, I've done it and almost everyone else who has done is says the same thing, it shifts like butta'.
#15 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
