Is having a D35 in the front bad? - JeepForum.com
post #1 of 8 Old 11-25-2008, 12:06 PM Thread Starter
pjleslie03
I know how bad the D35 is in the rear, but would it be bad to ahve one in the front?
I am looking at Jeep with ARBs in the front & rear with a D44 in the rear and a D35 in the front. Just wondering if the D35 would hold up as well as a D30 does.
I am not going for extreme rock crawling...but I would kit up some 3 Diamond trails at most.
pjleslie03 is offline
post #2 of 8 Old 11-25-2008, 12:07 PM
never monday
misprint, only the Ranger has a 35 in front
never monday is offline
post #3 of 8 Old 11-25-2008, 12:09 PM
Lostj
Lostj's Avatar
yes, you wouldn't be able to steer
00'TJ
74'CJ5 For Sale
Lostj is offline
post #4 of 8 Old 11-25-2008, 12:10 PM
littleman66
littleman66's Avatar
i dont undetstand....
are these axles full width?
what makes you think its a D35 and not a D30?
2001 60th Anniversary TJ.
2" BB. 31" Goodyear Wrangler MTR's
Dana44 LSD. front Aussie Locker
homemade rear bumper with hitch, two recovery points
dual battery. 1750 watt inverter
Dukes of Hazard/Dixieland horn. Neoprene seat covers
littleman66 is offline
post #5 of 8 Old 11-25-2008, 12:11 PM Thread Starter
pjleslie03
Must be a misprint. The guy has it listed as a D44 rear and a D35 front. He must have meant a D30.
Haha...I would say that not being able to steer is a bad thing.
post #6 of 8 Old 11-25-2008, 12:12 PM Thread Starter
pjleslie03
Thats what the guy wrote in the Craiglist ad. He has a ton of stuff done to it and he defeinitely knows what he is talking about. So I am guessing that its a typo.
I just didnt know if there was some other type of setup that I have never heard of.
post #7 of 8 Old 11-25-2008, 12:32 PM
KennyTJ
The only "front" Dana 35s were put into Ford Ranger, Bronco II, and Explorers. All were between 1983 and 1999.
The original front Dana 35 was a TTB (twin traction beam design). Kinda like an early version of IFS. The later front Dana 35s were IFS.
So to the OP, no the IFS or TTB version of the Dana 35 would not work out as well as a D30 front. If you want bigger then find a D44.
Silver '06 TJ w/ neat stuff on her!
"New" 1987 YJ Project for my son!
KennyTJ is offline
post #8 of 8 Old 11-25-2008, 12:57 PM Thread Starter
pjleslie03
Got it....thanks for the quick response everyone.
How to remove front wheel bearings/hub from front axle? Tshark299 YJ Wrangler Technical Forum 10 09-17-2010 08:55 PM
rc 2.2 front shocks but hard compression=rough ride in front restorod TJ Wrangler Technical Forum 16 04-18-2010 05:12 PM
Can a worn front axle pinion bearing cause poor steering/front end shimmy? golficon TJ Wrangler Technical Forum 2 02-28-2009 12:27 PM
lift installed, front DS hitting front crossmember need advice. kittyhawk TJ Wrangler Technical Forum 5 09-01-2007 10:43 PM
Can I disengage the front drive shaft if I have the Warn front axles? Nucklez YJ Wrangler Technical Forum 11 04-13-2006 11:53 AM
