Have questions about more axle droop? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Have questions about more axle droop?
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge BushingsStainless Steel Door Hinge Pins
Unread 08-09-2012, 05:40 PM   #1
pmcjeep
I have been looking at axle droop in relation to control arms. My jeep seems like at a certain point the control arm binds on the shock bracket in the front. I am still running stock lowers in the front and have thought about changing to tube style. Would these let the axle droop more or do i need to mod the bracket? I have seen where a couple guys have cut the bracket for more droop. If this is the case how much should i cut and anyone have any pics of this mod? Thanks.
01 tj 4.0,custom suspension,ecgs 8.8 and hp30 both locked with 4.88s,35in STTs,Smittybilt bumpers,8k winch,Highlined MCE flatties,TKHfab rocksliders,and lots more to come!
pmcjeep is offline   Reply With Quote
Unread 08-09-2012, 05:45 PM   #2
CrankyGypsy
Beef Punchmeat
CrankyGypsy's Avatar
I didn't/don't know how much everyone else takes out - I just up and cut mine. check my sig.
My 2004 Rubicon
CrankyGypsy is offline   Reply With Quote
Unread 08-09-2012, 05:45 PM   #3
Necko2529
Necko2529's Avatar
What's custom about a suspension when still using factory control arms?
Rokmen TT, Rokmen rear upper control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
Necko2529 is offline   Reply With Quote
Unread 08-09-2012, 05:54 PM   #4
pmcjeep
I ordered my springs and shocks seperate didnt buy a kit. So i didnt feel like listing all the things from the different companys that i have in my lift. Now do you have anything to helpful to add?
Unread 08-09-2012, 05:58 PM   #5
Necko2529
Necko2529's Avatar
How tall of a lift?
Unread 08-09-2012, 06:04 PM   #6
pmcjeep
3in suspension.
Unread 08-09-2012, 06:07 PM   #7
Necko2529
Necko2529's Avatar
Whose springs are they, not every manufacturer measurements equal out to what they advertise?
Unread 08-09-2012, 06:34 PM   #8
pmcjeep
Bds
Unread 08-09-2012, 07:46 PM   #9
SideshowBob024
The easiest and most effective option is better arms, like Savvy or Metalcloak etc etc. They will be narrower and should help your issue. They will also flex better, and once you have those you can determine if you need to trim, which should be much less than with the factory clunkers.
SideshowBob024 is offline   Reply With Quote
Unread 08-09-2012, 08:09 PM   #10
Sundowner
Part-Time Swami
Sundowner's Avatar
Personally, I'd swap my stock links for double adjustables with good joints and see where I got before I took the grinder to anything. Although the size of the lower link's cross section might be physically smaller, the improvements in articulation come from joints that are far superior to the stock control arm bushings.
The build, the gear, and the mileage: The Wasteland Survival Guide
Sundowner is online now   Reply With Quote
Unread 08-10-2012, 05:56 AM   #11
pmcjeep
Sounds good guys.
Unread 08-10-2012, 11:48 AM   #12
pmcjeep
I was looking at the metalcloak control arms and they look close in design to the newer joints that rc uses. Do you guys think they will hold up pretty good?
Unread 08-10-2012, 12:08 PM   #13
Imped
Balls
Imped's Avatar
There are no similarities between RC's flex joints and MC's bushings.
OlllllllO
Float Test Build
IndyORV
If you see a dead picture link of mine and would like it fixed, please PM me the link to the post and I'll fix it. Thanks
Imped is offline   Reply With Quote
Unread 08-10-2012, 12:10 PM   #14
pmcjeep
I guess i was looking at the ball type design in the bushing.
Unread 08-10-2012, 01:16 PM   #15
wheelinsw
the only companies i would consider for joints at this point in time is metalcloak and Currie JJ's. I just switched to the MC joints and the ride is amazingly smooth. Next month is the earliest i will be able to give a realistic first person experience with these as we are heading to the Rubicon then. JJ's are tried and proven no doubt though. with 3 inchs of lift I believe you would be hard pressed to find your brackets the limiting factor of your droop. I may be wrong though. get some adjustable arms/nice joints get it twisted and then figure out what your direction is going to be.
wheelinsw is offline   Reply With Quote
