Have any of you heard this before? - JeepForum.com
post #1 of 22 Old 05-16-2005, 07:19 PM Thread Starter
hexum08
Hi!
I am very interested in purchasing a 2001 Sport with 40,000 miles on it, however it seems to have one problem.
The current owner says the check engine light is always on because of the way he fills up his gas tank. Evidently, he is able to get his gas for free and tops himself off everyday at work, sometimes he forgets to shut the car off while filling up the tank. After doing this, the engine light comes on and stays on.
Assume you believe his story for a minute, would the check engine light come on if he filled up his car while running? I took a look at the engine codes which would correspond to this but didn't see anything (although there could be room for interpretation).
I'm going to look at the car tomorrow night (Tuesday) so please reply if you know anything of this subject. Thank you very much!! - Eric (my first post!)
hexum08 is offline
post #2 of 22 Old 05-16-2005, 07:25 PM
articulate
Originally Posted by hexum08
Hi!
I almost hate to answer this way, but I don't buy this "sometimes I forget to turn off my car when filling up" crappola.
"Sometimes I forget to disclose all of the problems with my car to prospective buyers."
I don't know, dude. Caveat emptor.
articulate is offline
post #3 of 22 Old 05-16-2005, 07:25 PM
Spiderman
Spiderman's Avatar
Hi!
Sounds like a story, however sometimes if the gas cap isn't seated properly it can cause problems, but I don't remember what problems.
2001 Sport 4.0L, 5 Speed, Patriot Blue
33 X 12.50 BFG A/T's with A/R Atlas 15 X 8 wheels
4.56's, RE 3.5" lift, Currie 1" BL, M.O.R.E. 1" MML
Aussie D30 Locker, & other crap
Spiderman is offline
post #4 of 22 Old 05-16-2005, 07:30 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
test drive it to auto zone and have them check it
RnEmOvr is offline
post #5 of 22 Old 05-16-2005, 07:56 PM
nocturne
I was thinking the same thing. Take it to Autozone they will check it for free. Usually the O2 sensor has gone bad. It cost about $50-60 bucks to replace depending on the make and model.
BTW make sure you are wearing boots when you talk to the guy cause the BullSh!t is getting deep around him
If harley built an airplane would you fly it
03 KLR 650
00 SuperHawk
03 X
nocturne is offline
post #6 of 22 Old 05-16-2005, 08:00 PM
RLD831
RLD831's Avatar
I have a 2001 SE and the check engine light won't come on, but if the gas cap isn't clicked the critical engine warning light will come on. Its the yellow one, not the red one. To fix it you just have to twist the cap 'til it clicks. If it is in fact the red check engine light, then he is just plain lying.
RLD831 is offline
post #7 of 22 Old 05-16-2005, 08:04 PM
Alec
Autozone dude .... get it checked.
If it is the gas cap thingy, go for it. If it is not, run as fast as you can.
I know that TJ;s are like puppies .... one cannot resist to save one from a bad owner.
97 Green Sahara -
Powertrain envy sufferer - Softop tinkerer
Alec is offline
post #8 of 22 Old 05-16-2005, 08:09 PM
jeeper13
jeeper13's Avatar
1985 CJ8
I know that JEEP's are like puppies .... one cannot resist to save one from a bad owner.
good one, fixed it for you though
at 1st I was thinking BS, but it could be the fuel cap after thinking about all the TJ owners I have read about who failed inspection due to a bad gas cap..
but do like the others above said, take it to the zone to get tested.
good luck
Don't forget to :wave:
Parrothead Jeep club member #13
jeeper13 is offline
post #9 of 22 Old 05-16-2005, 08:14 PM
GUMSHOO
Not sure about a jeep but several vehicles will do this if the gas cap is not seated and the engine left running while you fill up. If you then drive away it creates some kind of vapor lock or air pocket causing the computer to sense something is wrong. It can be reset by the computer fairly cheap . Good Luck
GUMSHOO is offline
post #10 of 22 Old 05-16-2005, 09:19 PM
ColoradoTJ
ColoradoTJ's Avatar
He most likley is being truthful about what he feels the problem is, but why risk it. Even if the light was not on I would take it in had have it looked over.
Clint
"If we weren't all crazy we would go insane" J.B.
ColoradoTJ is offline
post #11 of 22 Old 05-16-2005, 09:31 PM
03jeeper78
03jeeper78's Avatar
I accidentally drove the 1 mile home from the gas station with the gas cap off once. The check engine light does come on, and the Jeep idled very very strangely. It would rev itself while I had the clutch in during a gear shift. It did that for about 2 days untill the pressure and everything had equalized or whatever it does and it was happy again. The light went off on its own.
'03 Bright Silver Metallic TJ Sport
BSMCCEP Club Member #45
Stock: 4.0L I6:5-speed:3.07 gears:D35 with Trac-Loc:15x7 Ecco wheels:Dual Top Group
Mods: 30x9.5 BFG A-T T/A KO's:JKS Quicker disconnects:Rock-It Man rocker guards:Jeep Medic oil pan/tranny skid:Kilby steering skid:Warn D30 diff guard:C4x4 D35 diff guard:Rusty's radiator guard:Skid Row LCA skids:SilverStar headlights and fogs:Hidden Hitch class III receiver:Old Realistic 40ch CB:2' Firestik II:Arizona Rocky Road tailgate antenna mount
Next : Jeeperman rear bumper
'06 Candy Orange Honda Shadow Spirit 750
03jeeper78 is offline
post #12 of 22 Old 05-17-2005, 07:36 AM
JezterVA
Yep, same here. Someone decided to siphon some gas out of my tank one night and left the cap off. The Yellow engine warning light came on and went off on it's own after about 4-5 days of normal drivng.
2004 Yellow Rubi
(Stock, but saving my pennies) :)
JezterVA is offline
post #13 of 22 Old 05-17-2005, 07:43 AM
jeepman14wheel
jeepman14wheel's Avatar
It happened to me also, the cap was not tight and the light came on. Once the cap was tight, the light went off after about an hour. It could be the cap, but like everyone else, take it to Autozone.
RE 3.5 lift, 1" BD/MT lift, 33.12.50 MTRs, Teralow, SYE, Detroit locker, Eaton E locker, Dana 44 front, Ford 8.8 rear, warn winch, full roll cage, Fuel cell.
jeepman14wheel is offline
post #14 of 22 Old 05-17-2005, 07:47 AM
two4zero
this is accurate
If he does in fact top off the car with it running it can potentially cause the check engine light to come on. Check with any automotive dealer and they will tell you the same thing. I should know I have worked at several. Anyway, all you should have to do to turn the light off is to unhook the battery for about 5 minutes. This will reset the light. If you are going to test drive it do this first before driving. That way when you get in the car and start driving you can watch the light. If it come on again it is something other than him filling up while it is running. If it stays off he is accurate in what he is telling you. You can also do as these others said and take it to auto zone but the way I mentioned may be easier for you.
Matt (two4zero) 99 wrangler SE army green (pretty close anyway) 31" BFG A/T's. 4cyl
two4zero is offline
post #15 of 22 Old 05-17-2005, 08:03 AM
Baas
Baas's Avatar
Check engine light can be reset. Remove the positive battery terminal for about 2 minutes. Reconnect and start up. The light should be out if the problem is sorted.
Errors stay in the memory and resets after a number of start ups.
04 Sport
4" Currie lift with Anti-Rock
Rock Krawler 4 link rear
Skyjacker 2" body lift
Safari Snorkel
35" Procomp X-terrain
Mickey Thompson Classic lock
Aussie locker front & rear
4.88 gears
CV Drive shaft
4WD SYE
215 Ponies I6
Baas is offline
Has Anyone Heard of This? CheapSunglasses YJ Wrangler Technical Forum 25 08-30-2008 07:49 AM
anybody ever heard of this? brundz YJ Wrangler Technical Forum 5 08-09-2008 08:42 AM
Have you heard of this.. JoeADB JK Wrangler Technical Forum 11 04-23-2008 05:38 AM
Anyone heard of these? harley_sr TJ Wrangler Technical Forum 2 01-12-2007 05:45 AM
never heard this one silvergreentj TJ Wrangler Technical Forum 3 02-22-2005 03:41 PM
