Have an Antirock? I need your help. - JeepForum.com
post #1 of 9 Old 05-16-2013, 02:58 PM Thread Starter
ytowntj
I'm looking for a few dimensions on an antirock if someone wouldn't mind measuring.
I'm looking for OD of the bar at the center and At the end as well as the distance from the top of the D shaped opening for the cross member to where the bar starts.
If anyone can grab any of these dimensions I would be grateful.
Parting my TJ:
My build - Odd approach to 33's
ytowntj is offline
post #2 of 9 Old 05-16-2013, 06:35 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Sorry i'm in Asia till next week.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #3 of 9 Old 05-16-2013, 07:39 PM Thread Starter
ytowntj
Thanks Gerald. I'll be buying it from you either way, I'm just trying to find out if it will fit in my modified cross member
Parting my TJ:
ytowntj is offline
post #4 of 9 Old 05-20-2013, 12:27 AM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
You shouldn't need to modify the cross member.
Thanks!
Like us on Facebook
Savvy is offline
post #5 of 9 Old 05-20-2013, 01:21 AM Thread Starter
ytowntj
My cross member is notched for a sunken winch mount already. I'm trying to figure out if I can run an antirock. The top 3/4 inches is notched at the center
Parting my TJ:
ytowntj is offline
post #6 of 9 Old 05-20-2013, 08:53 AM
Offshoredrillin
the bar on the antirock is wider on the outside edges than in the middle, the outside diameter is right about an inch, the whole cross member is about 3 inches for the d shaped plug, you should be fine.
Offshoredrillin is offline
post #7 of 9 Old 05-20-2013, 09:16 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Doesn't matter. It would be very easy to have some UHMW machined up to fit the D shaped hole and then have the hole for the swaybar drilled lower.
That said, if you know that the cut-out is no more than 3/4", the drop center of the swaybar should easily clear that.
The ends of the bar are roughly 1 1/16 OD and the drop center is roughly .750.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #8 of 9 Old 05-20-2013, 10:14 AM Thread Starter
ytowntj
Thanks blaine. I have access to the equipment for this, but I was curious if it would work in stock form. Knowing ahead of time reduces the amount of time my dd is out of commission. I'm not trying to drive with no swaybar in the ridiculous traffic around here.
Parting my TJ:
ytowntj is offline
post #9 of 9 Old 05-20-2013, 10:16 AM
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
any pictures of your sunken winch mount? just curious
SEMPER FI
LifeProof is offline
