Quantcast Have $5000, ready to make mods!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Have $5000, ready to make mods!!!
Old 11-23-2003, 02:14 PM   #1
grneggz
I have the cash to make some mods now and I am hung up on the size of tire to go with. I have a dana 44 rear and dana 30 front and both will be locked up. I want 35's, but thinking about getting 33's. I know there isn't hardly any difference, but I am concerned about snapping the front axles with 35's, but I'm sure that this all depends on how hard you are on the gas pedal. All of you guys that are breaking your alxes, what kind of wheeling were you doing when they broke? Rocks? I'm curious.
Also, I know that you can buy warn or superior replacement axles, but I haven't read much about breakage from people with 33's. Really, how much more advantageous are the 35's gonna be?
The money is burning a hole in my pocket and the tire size is my only dilemma..........
Any and all help is appreciated!
2003 TJ Sport
Banks Header & Cat
1" M.O.R.E. BL
Rear Dana 44 w/ discs
grneggz is offline   Reply With Quote
Old 11-23-2003, 09:05 PM   #2
TJ=MT Pockets
well, all I can say is if your thinking about 35's get them. If you go with 33's you will end up regreting your decision. As far as axles go, from what i read, the JV guys are running 35's on their d30's with the warn hub kit with good success. But, I guess it all comes down to where and what kind of wheelin you do. So, as far as making a suggestion, I don't know if the trails you run "require" 35's or if 33's will do. Good luck with your decision, let the fun begin. For the wheelin I do, I'd run 35's, 4.88's, arb's (I have a detroit and sometimes it acts up too much for a DD) and a tera 4-1 kit. But I do mostly rocks.
Y2K 4L 5spd TJ Sport--4.5" RE SF all adj. arms--1" BL--1" MML--33"bias swampers(soon to be 36" swamper sx's on rockcity diy beadlocks)--D44 4.88's arb w/alloy usa shafts--HPD30 4.88's locrite w/warn alloy inners--warn small hub kit--longfield hd u-joints--currie steering--currie anti-rock--tera low--A-Z Fab cage--and a bunch of skids
TJ=MT Pockets is offline   Reply With Quote
Old 11-23-2003, 10:39 PM   #3
TellyDSP
Poland and PPV!!!!
I would say go 35's. The D30 is fairly strong and it should be fine with the 35's. It really depends how rough you are on the skinny pedal. What kind of lift are you doin? Also with the 35's you would want to regear 4.56 or 4.88. 4.88 would be a little more torquey if your crawling. The 4 to 1 kit would be nice. It depends what kind of riding you do. The 35's will give you aq little more clearance on the diffs too.
My .02
Craig
-Craig-
95 Rio Grande
07 Ram 1500
SIRA4x4 Club
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline   Reply With Quote
Old 11-23-2003, 11:00 PM   #4
JeepinAmerica.com
Do yourself a favor, dont drop a penny into you D30. With 36in SX, replaces two hubs, one r and p, lost count on how many axle shafts. But I also had a full detroit, which in my opinion, is the only way to go.
Not one problem with the 44.
INVEST in a front 44, and lock and gear both ends. Save up little more money and get a lift and tires.
Build it once, build it right
01 Flatfender Sahara.
1 ton axles, full width
Mods listed on my site
[url]www.JeepinAmerica.com[/url]
Tow vehicle: 01 F350 Dully, turbo deisel, crew cab,
JeepinAmerica.com is offline   Reply With Quote
Glock Forum
