Has anyone ever had "custom" roll bar pads made? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Has anyone ever had "custom" roll bar pads made?
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! ECGS Black Friday Sale!!Thanksgiving/Black Friday/Cyber Monday Deals at JeepinOutf
Unread 06-29-2009, 08:50 PM   #1
GotLime
Has anyone ever had "custom" roll bar pad covers made?
I have an 04 TJ Rubicon. The install of my RockHard cage should be done tomorrow. I have the front section, the rear angle bars and the rear spreader bar. I bought the pads for the RH cage, but that leaves me with no padding anywhere else. The factory pads have to go because of how the cage mounts and they only sell the pads to cover "their" bars. Does that make sense?
I was thinking of going to a boat cover place and seeing if they could make something to cover the factory bars.
Anyone else have any ideas?
This Jeep is not a daily driver, but I do drive it most weekends with my 7 and 9 year olds in the back seat.
GotLime is offline   Reply With Quote Quick reply to this message
Unread 06-29-2009, 09:12 PM   #2
KnightFire
When I padded the cage in my car, I used pads from SummitRacing.com. I'm guessing you want something quite a bit more finished in appearance?
http://summitracing.com/search/?keyw...0padding&dds=1
2002 TJ Wrangler "X" Patriot Blue 4.0L
1993 Formula Firebird Cardinal Red 355CI
2004 Dodge Ram Hemi-Sport Flame Red 5.7L 4x4
2006 Toyota 4Runner Sport Titanium Metallic 4.7L 4x4
KnightFire is offline   Reply With Quote Quick reply to this message
Unread 06-29-2009, 09:18 PM   #3
ridendirty
http://www.fullsizexjgear.com/more/sportcages.htm
Check out the bottom of the ad.
ridendirty is offline   Reply With Quote Quick reply to this message
Unread 06-29-2009, 09:22 PM   #4
GotLime
That's a good place to start. I guess I should have asked if anyone has had custom covers made.
I know nothing about the padding itself. Which one is best? I assume SFI rating is good. Is thicker padding better?
Unread 06-29-2009, 09:24 PM   #5
Jeepguy1977
depends on how hard and how often you hit your head on it.......
1998 TJ, 4.0L Auto and various junk
Rolled Red Jeep Club Member #7
Jeepguy1977 is offline   Reply With Quote Quick reply to this message
Unread 06-29-2009, 09:26 PM   #6
GotLime
Originally Posted by ridendirty View Post
Thanks. That looks good. Do you have to call for pricing?
Unread 06-29-2009, 09:31 PM   #7
ridendirty
I don't know anything about the company. I just saved the site for when I install my full cage. If you get some, let me know how you like them.
Unread 06-29-2009, 09:35 PM   #8
JBWood05TJ
Cut to Fit-Paint to Match
JBWood05TJ's Avatar
I used 1-3/4" ID X 5/8" thick pipe insulation and a bunch of electrical tape.
You can see some of it here:
As you can see, I've got the RH cage too, and I also have the diagonals and rear spreader like you have.
That stuff with the velcro looks nicer, but it also looks expensive. I figure if I get up against a tree or something with mine, I can replace the whole length for a couple of bucks.
JBWood05TJ is offline   Reply With Quote Quick reply to this message
Unread 06-29-2009, 09:38 PM   #9
GotLime
How do you like the cage? Any drawbacks? Any issues? Anything you would change if you did it again?
Unread 06-29-2009, 09:38 PM   #10
KnightFire
Here is some light reading regarding SFI:
http://www.sfifoundation.com/
I wouldn't buy roll bar padding unless it was SFI 45.1 approved, as it's demanded by the NHRA, but you won't have to stand up to techs/inspections for your Jeep . All things considered, I'd still only purchase SFI 45.1 approved padding, no matter what the vehicle is. That is JMHO though.
The thickness of the pad is completely up to you, what you need, what space you can actually use, and what you feel looks right.
Unread 06-29-2009, 09:45 PM   #11
JBWood05TJ
JBWood05TJ's Avatar
I like it just fine. I started with the basic kit about a year and a half ago and added the diagonals, the rear bar, and frame mount over time. Oh, and the front and rear harness bars. Hopefully, it'll never be used for it's intended purpose. But if that day ever comes, I'm confident that the cage will protect the family and me.
Unread 06-29-2009, 09:48 PM   #12
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
I used cheapo Kirkey padding from ebay for some of cage. I also cut up the stock padding & covers, but I regret that because they look like crap and the zippers don't stay put.
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 06-29-2009, 09:50 PM   #13
GotLime
I thought about modifying the stock pads/covers, but the zippers are the problem.
Who knew you needed to be a seamstress to own a Jeep? :lol:
Unread 06-29-2009, 09:54 PM   #14
Unlimited04
it took me like an hour to re-thread the zippers together after cutting the B and C-pillar padding apart. it seemed like a reasonable idea at the time, but i definitely regreted it after the 1st zipper.
Unread 06-29-2009, 10:10 PM   #15
Alexia
New zipper pulls can be bought at a place similar to JoAnn. Before cutting through the zipper put new metal zipper end clamps in place on each side of where the cut will be. Once it is cut all that needs to be done is putting the new zipper pulls on.
I have been considering making green padding to match the exterior color. Making your own padding should be very easy considering it is a flat section of fabric folded and zipped together.
Disclaimer: I am a seamstress and own a Jeep. :P
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Build Project Thread
Rocker Guard Comparison Chart - Final Differential Gear Ratios - Oxygen Sensor FAQ
Alexia is offline   Reply With Quote Quick reply to this message
