Has anyone actually broken a D30 or D35? - Page 3 - JeepForum.com
post #31 of 40 Old 05-26-2011, 07:38 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Broke a Dana 35c R&P and gear case together with an axle shaft with 33" tires and a locker on the street, and broke a stock Dana 30 passenger-side axle shaft with 35" tires and a locker on a very tough trail (Sledgehammer in JV).
Jerry Bransford is offline
post #32 of 40 Old 05-26-2011, 07:47 PM
Major Pain
Junior Member
Major Pain's Avatar
2011 JK Wrangler
I am a CNC Machinist and have had some great opportunities in the past to build some awesome equipment. I have made ring and pinion gears and been in on the heat treat process and grinding. I have made axles and carrier housings. I no longer work in that field but it was fun.
but I did learn an industry secret that I will let you all in on.........
the single greatest cause of all equipment failure is.........
PEER PRESSURE
because if no one was watching I wouldnt have tried it
Major Pain is offline
post #33 of 40 Old 05-26-2011, 08:02 PM
chadsmeltzer
chadsmeltzer's Avatar
I broke my D35 on 31s while driving down the road. I broke my D30 locked on 35s bouncing off a stump in reverse uphill. I think I deserved that one.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #34 of 40 Old 05-26-2011, 09:14 PM
AntiPrius
double post
AntiPrius is offline
post #35 of 40 Old 05-26-2011, 09:15 PM
thirdeye
Originally Posted by cj777 View Post
x2 I broke my Dana 44 with stock 3.73 gears, 33s, and no locker. I would hate to have seen how long a 35 would have lasted.
Dang you musta been wheelin hard!
Mine didn't break till I locked it with an OX. And I have 4.10s
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
post #36 of 40 Old 05-26-2011, 09:15 PM
AntiPrius
My D35 broke because I called it bad names.
post #37 of 40 Old 05-26-2011, 09:25 PM
Pikes_Peak_Trailers
Yes, 33s, D30, Torsen locker and way too much throttle.
Pikes Peak Trailers LLC.
Hand Built Off Road Trailers (customized for you)
Pikes_Peak_Trailers is offline
post #38 of 40 Old 05-26-2011, 09:43 PM
thonyg523
broke a locked D35 with 34" super sampers being careless and also falling into peer pressure ...broke about 3 teeth off of the ring gear. After doing that i thought hell might as well just swap it with a dana 44 and iv been okay ever since
P.S to anyone wanting to buy a rear detroit locker for a D35 with 30 spline shafts that came from this whole mess; im selling the combo for $500/obo. i live in Colonia NJ (central NJ) and need to get rid of this thing already! its pick up only and please call or text me (tony) at 908-463-9179 at anytime to those interested. sorry for the plug in!
thonyg523 is offline
post #39 of 40 Old 05-29-2011, 07:42 PM
twigman
I stripped the splines off of the passenger side axle on the rear of my Cherokee. D35, 4.10, open diff and 33's. I was on the road and about to accelerate into traffic. Not a terribly aggressive start. So now it is front wheel drive for a while...I'll pretend it is a Compass.
The splines on the axle were badly worn. $60.00 at Pick n Pull, and the old girl is back on the road.
twigman is offline
post #40 of 40 Old 05-29-2011, 07:45 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
D35 twice... with 33x12.50x 15x8"superior axles and a Detroit Tru Trac.
GOLENJEEPTJ is offline
axles , dana 30 , dana 35 , jeep wrangler
need help! broken bolt extractor broken. fltj TJ Wrangler Technical Forum 14 04-18-2008 01:32 PM
still broken ac lokua TJ Wrangler Technical Forum 5 07-23-2006 09:18 PM
Broken into absentiabanish TJ Wrangler Technical Forum 21 07-17-2006 03:23 AM
TJ broken into absentiabanish TJ Wrangler Technical Forum 25 04-11-2005 12:41 PM
Broken axles, broken carrier and gears.. (pics) Texasmudder TJ Wrangler Technical Forum 34 03-15-2005 09:59 PM
