Hardtop Wiring Kit - JeepForum.com
post #1 of 6 Old 08-24-2007, 02:20 PM Thread Starter
t2sj
Hardtop Wiring Kit
I just bought a used hardtop for my 2004 Wrangler Unlimited. I've seen the wiring kits for sale on the internet to connect the defrost and wiper. How hard are they to install (I'm not very mechanical)? Do they also come with tubing to connect to the washer fluid or will I have to buy that separately? Any advice anyone has would be great. Thanks!
t2sj is offline
post #2 of 6 Old 08-24-2007, 02:37 PM
grinwa
grinwa's Avatar
I've looked into this myself and found that the dealership is actually cheeper by about $10 and no shipping. (compaired to quadratech). I comes with all the wiring, switches, hoses, and new washer fluid bottle.... everything you need to hook it up.
'99 TJ
Experience is something you don't get until just after you need it.
grinwa is offline
post #3 of 6 Old 08-24-2007, 02:58 PM
CCrew
CCrew is offline
post #4 of 6 Old 08-24-2007, 04:04 PM
Wheels-Up
Originally Posted by t2sj
...How hard are they to install (I'm not very mechanical)? Do they also come with tubing to connect to the washer fluid or will I have to buy that separately?
1. The factory kit is complete, including all the wire, hose, switches, relay, new double-pump reservoir, etc that you will need.
2. It is an "easy" installation -- it IS a bit tedious, BUT the factory instructions are very detailed -- just take your time and do exactly what they say (in the order they give).
3. BUT!!! here's a possible catch! -- is the hardtop you purchased from a 2004 model Wrangler? If "yes," then no worries. If "no," then MAYBE a worry...but it's solvable. The issue can be differing electrical connector halves -- the half on the top might not match the half you get in the kit. I ran into this problem when I put my kit in (a 2004 top onto a 1998 TJ)...here's a thread detailing the connector half (they call it a "connector repair kit") you will need to purchase from the dealer IF you encounter this problem...
http://www.jeepforum.com/forum/f9/connecting-different-year-hardtop-your-tj-electrical-163514/
Wheels-Up is offline
post #5 of 6 Old 08-24-2007, 04:26 PM Thread Starter
t2sj
Thanks for the quick replies. The top I bought is also from a 2004.
t2sj is offline
post #6 of 6 Old 07-28-2011, 08:05 AM
autopc25
http://www.jeepforum.com/forum/showthread.php?t=163514
I have a early 1997 and bought the Mopar Hartop wiring kit for a 1997-2000. I installed everything OK until the last 2 wires. One is a Lt. blue/white and the other is a Dk. blue/Lt. green wire. The directions say to locate RH (passenger side) 10-way I/P. I took out the glove box and can not locate this 10-way?
Step #41 in the instructions said to remove the RH (passenger side)10-way I/P cluster. Where is this?
Step #42 said to remove 3" of tape from the connector.
Step #43 said to insert Lt. blue/white into cavity #3 of the connector and Dk. blue/Lt. green into cavity #4.
There is also a special note for 1997 Models.
On '97 models, replace these 2 terminals with the loose terminals (item 13) supplied in the kit. Solder these connections!
I have the 2 loose terminals.
Where is the right hand side 10-way cluster located?
What do the 2 wires connect to?
autopc25 is offline
Help With Hardtop Wiring Kit RAI TJ Wrangler Technical Forum 12 07-28-2011 08:43 AM
Hardtop Wiring - '01 TJ rpeatman TJ Wrangler Technical Forum 2 09-28-2009 04:51 AM
hardtop wiring ucbandit10 TJ Wrangler Technical Forum 1 10-01-2007 09:58 PM
Hardtop wiring tufmar YJ Wrangler Technical Forum 2 09-08-2007 07:53 PM
YJ Hardtop Wiring TimWelty YJ Wrangler Technical Forum 14 09-26-2004 09:42 AM
