Hardtop rear window seal - JeepForum.com
post #1 of 4 Old 10-17-2009, 05:27 PM Thread Starter
captain_andrew
Have had problems with my hardtop leaking in heavy rain around the corners of the rear glass seal. The piece of napkin i stuffed in there is to show where the hole is i know its hard to see. I'm wondering if i am actually missing a piece on the end of the seal or something maybe someone can compare it to their hardtop seal and tell me if it looks different
captain_andrew is offline
post #2 of 4 Old 10-17-2009, 05:31 PM
prd_cdn
prd_cdn's Avatar
I was changing my hinges on mine today and noticed the same thing.
6 years and I never noticed.. so your not alone. Only thing I can think of is maybe some foam tape or something to 'stuff' in there like you've done with the TP.
Good Luck !!
prd_cdn is offline
post #3 of 4 Old 10-18-2009, 03:15 PM
BlueFlame
BlueFlame's Avatar
I took some pics of mine.
See pic: PA181446comp.JPG - File Shared from Box.net - Free Online File Storage
The two rubber bits should rub each other and seal at points marked A and B. See how mine obviously touches (because it is clean where they touch.)
Best way to fill that gap would be a small piece of self-stick weatherstrip stuck on where I marked A or B. (Obviosuly clean the surface well first.)
BUT - I bet that's not where it leaks. The top molding makes a little ledge where I marked C. The water puddles on this ledge, then runs behind the weatherstrip that goes around the perimeter of the window opening. I had leaks there on both sides. A little silicone (RTV) applied right at the bottom of that ledge against the edge of the seal (where I marked C) will stop the water from getting through the little gap and force it run out the back like it's supposed to.
BlueFlame is offline
post #4 of 4 Old 10-18-2009, 03:31 PM Thread Starter
captain_andrew
That could very well be it it only seems to leak when parked with the front of the vehicle facing downhill. I'll go try that right away
TJ Hardtop Rear Window - anything else fit ? rpeatman TJ Wrangler Technical Forum 2 07-19-2009 12:13 PM
hardtop rear window help 472cid TJ Wrangler Technical Forum 9 01-27-2009 10:06 AM
Hardtop Rear Window Krams04 TJ Wrangler Technical Forum 6 09-13-2008 08:55 AM
Hardtop rear window? djennis20 YJ Wrangler Technical Forum 13 10-11-2006 08:11 PM
Hardtop Rear Window blacktj TJ Wrangler Technical Forum 1 12-06-2002 12:24 PM
