Hardtop Liner *LOTS of pics* - JeepForum.com
post #1 of 21 Old 10-18-2006, 08:37 PM Thread Starter
samger2
So after posting here and taking some advice *thanks Jerry and others! * I decided to line my hardtop before the winter...first I gathered my supplies which consisted of spray adhesive, foil backed insulation (both purchased from JC Whitney) and finally speaker box carpet which I got 18 feet of for free at a local shop!
After gathering supplies me and a buddy cut the instulation to size in two pieces and adhered it insulation side out to the hardtop, the instructions said to always have the foil side facing the source of noise or heat...I figured even though the inside was the source of heat, the outside was the source of noise and that was most important to me
Next step was to cut the carpet to length. I did that, sprayed both the carpet and the liner and adhered them together
Once in place, I then took a razor box cutter and cut the edges clean, and finally the finished product
I've yet to put the top on for the season, but I'm really looking forward to seeing how much it helps! Thanks again to all who gave me advice!
Sam
samger2 is offline
post #2 of 21 Old 10-18-2006, 08:40 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
should help quite a bit, though most road noise comes in through the floor boards, lineing those should be your next step!
good luck!
My builds:
and
or follow us on
spyder6 is offline
post #3 of 21 Old 10-18-2006, 08:44 PM
SecondTJ
SecondTJ's Avatar
did you do this for noise or to keep heat in? and what was your total cost?
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #4 of 21 Old 10-18-2006, 08:45 PM
EaglesSJ
EaglesSJ's Avatar
Looks great Im anxious to see if it cuts down on road noise. I hate all the noise my jeep makes on these long trips home. I cant even hear my radio!
EaglesSJ is offline
post #5 of 21 Old 10-18-2006, 08:49 PM Thread Starter
samger2
Well a little bit of both actually. My total cost when it was all said and done wasn't much over $50.00. I think the spray adhesive and insulation was about $45.00 and I ended up having to go buy another can of spray adhesive...and this time I bought a cheaper brand under $5.00...but I did luck out and get the carpet for free.
samger2 is offline
post #6 of 21 Old 10-18-2006, 10:49 PM
blacktj27
blacktj27's Avatar
Looks nice I have been thinking of putting that insulation on the entire tub of my jeep to see if it helps for the road noise and with the winters here. How hard was that insulation to work with?
04 TJ Sport (Black)
AFW front bumper, ARB snorkel,
windshild mount KC Daylighters,
dana 44, 3.73 gearing, KC fogs,
RE3.5, 32x11.5 Kuhmo MTs,
KC backup lights, PSC diff. guard,
LoD bumper/tire carrier,
1"MORE MML, 1.25" JKS BL,
Pioneer AVIC-N2, Ultimate Air,
Novak T-case shifter, Warn 9.5ti,
PSC dana 44 bomb shell
blacktj27 is offline
post #7 of 21 Old 10-19-2006, 07:05 AM
GeoBigJon
Cactus Hobbit
GeoBigJon's Avatar
2014 JK Wrangler
I wounder how well its going to stay up there. We have some 80 and 90 degree days here in the middle of winter. Looks good and clean, my only concern would be the adhesive letting go. I have thought about a liner similar to that on the HT and a spray in liner on the tub. Let us know how it holds up and how well it works for sound and insulation.
2014 JK Anvil Rubicon
If you eat, drink, or wear cloths then you're involved in agriculture.
GeoBigJon is offline
post #8 of 21 Old 10-19-2006, 12:10 PM Thread Starter
samger2
Thanks. The insulation wasn't hard at all to work with. Just make sure that you have another person to help you lay it down once you spray it with adhesive otherwise it sticks to itself and other stuff around it and starts pulling the threads of the insulation out
samger2 is offline
post #9 of 21 Old 10-19-2006, 05:27 PM
Oman Jeep
Oman Jeep's Avatar
Looks good... I wanna do something similar, but all the way down around the windows... Just gotta figure out a nice way to trim the edges around the glass...
Oman Jeep is offline
post #10 of 21 Old 10-19-2006, 07:41 PM
AZG23
yeah...I was worried about the heat here...it gets up to 140 degrees inside vehicles here in the summer....dunno how well it would hold at that heat...
Brad B.
"If you cant understand that, your face needs to be set ablaze with kerosene and promptly put out with a wet brick."
AZG23 is offline
post #11 of 21 Old 10-19-2006, 08:18 PM
UnsanePyro
The cheapest easiest thing I have found to do is to put a piece of electrical tape the length of the hardtop where it meets the windshield frame, cuts down on the wind noise a TON
UnsanePyro is offline
post #12 of 21 Old 10-19-2006, 10:41 PM
NEWtoTHEjeepLIF
Was that the thread I posted in?
I used stuff that is made to spray in the engine bay to hold hood liners up. 80-90 degrees should not be a problem.
NEWtoTHEjeepLIF is offline
post #13 of 21 Old 10-19-2006, 11:35 PM
Michael_K
Michael_K's Avatar
If you are worried about the adhesive holding up, get SecondSkin Audio's Damplifier.
It made through GA summer easily.
I topped it off with liner.
Michael K.
DailyDrivenTJ.com
JUST For Jeep TJ Owners Around the World!
Michael_K is offline
post #14 of 21 Old 10-20-2006, 01:05 PM Thread Starter
samger2
I'm not worried about that because I only use my hardtop in the fall and winter when it's cool to cold out
samger2 is offline
post #15 of 21 Old 10-20-2006, 01:20 PM
jeepin_man
not to sound like a jerk, but if you are worried about your radio, what do you do in the summer?
jeepin_man is offline
inside hardtop blacked with duplicolor truck bed liner JK-RUBIJON JK Wrangler Technical Forum 54 05-27-2012 08:23 PM
Homemade Hardtop Liner Ferret TJ Wrangler Technical Forum 11 10-21-2009 06:41 PM
Hothead Hardtop Liner tufmar TJ Wrangler Technical Forum 8 09-30-2009 08:12 PM
Hardtop Liner.... maddawgxxl TJ Wrangler Technical Forum 14 11-05-2008 09:36 AM
Hardtop liner Photojeep TJ Wrangler Technical Forum 2 09-19-2006 11:28 AM
