Hardtop insulation ideas for Canadian winters?
| TJ 5.25" Speaker Adapters - NalinMFG | Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed |
#1 | |
I've read through a few threads here on the forum and done a fair bit of research on the web for a product that can either be purchased as an "install in one piece" or ideas for a DIY project. I come up with many threads related to hardtop insulation for hot climates such as down south in the States, but barely anything relating to keeping the heat IN the Jeep with the hardtop on for Jeeps in cold climates.
I use my vehicle for work and am in it for great amounts of time without the engine running. I'd like to be able to run the engine, warm up the cab and then turn the engine off and retain the built up heat for longer than what the thin fiberglass hardtop allows. Our Canadian winters get cold, eh? Does anyone have any ideas? Have you done such a thing before? Pictures would be awesome if anyone has them. Thanks in advance guys and gals.
Savvy Off-Road: http://www.savvyoffroad.com |
#2 |
Ever considered the spray foam insulation? Not the Great Stuff in a can, but some actual professional 2 part expanding foam they use in retrofitting houses with insulation? I'd bet you could spray an inch or 3 of that on your top and shape it to whatever contour you wanted and glue a headliner to it if you wanted.
I've never used it in that sort of application, but have seen it being sprayed in the stud bays of houses and a quick pass of it will net you several inches of foam. It is pretty sticky too. Something to consider. |
#3 | |
Keep the ideas coming though...they're all helpful.
#4 |
While I think it would help insulating the hard top I don't think it will fix the issue. The tub would need to be done too as it never really gets warm with the heater on.
*****TJ Tech BOOT CAMP***** A must-read for new TJ owners/forum members |
#5 | |
How about a heated seat cover? |
#6 |
As mentioned before, you are probably going to have to take care of several things to really get the warmest possible cab. You should probably add insulation, and a heat source.
I would think you should insulate the hardtop like what you are talking about. Add a LOT of insulation under the carpet, because there really isn't any at all. If you are worried about it getting wet in the summer, keep it removable. This will also have the side benefit of making your Jeep pretty quiet on the road. Then, to really make it better for sitting without the engine running, get a second battery and one of those electric heaters with the fan. That way, the temperature in your almost well insulated cab can be maintained without the engine running, for quite a while.
Ron Paul Was Right Been on the rails and Big Muddy. I've crossed the trails rocky and rutted. Been down the road a million miles, But I still got a long way to go. |
#7 |
Took a piece of that foam board with the silver foil backing on both sides, cut it to the shape of the top.
The used velcro to stick it in place. It's replaceable, removeable, and cheap. The foil back will help retain heat. You could also use a spray on liner like herculiner or duraliner. Do the chevy heater motor mod? |
#8 |
Pretty much the best it's going to get I think. That and/or heated seats.
'98 TJ Sahara |
#9 |
Insulshield Technology
Cab Insulation I've seen that foam headliner from db engineering in tractor cabs. If I can get some one to go in "halfs" with me, I might buy a roll to do my (our) roofs. ![]() |
#10 |
pricey but nice CALIFORNIA TOPS – Offroad Tops for Jeep Vehicles
1997 TJ SE - Emeral Green Pearl 2.5L : AX-5 : NP231, D30HP : D44 : 4:88 : Front Aussie 2.5" OME lift, OME LT shocks, 2" BL, Currie Control Arms, Currie HD Steering, Currie Trackbars, Warn M8000 Custom Front and Rear Bumpers, Custom Rock Sliders, OBA 33" x 12.5" x 15" Goodyear MTRs, Black Steelies |
#11 | |
#12 | |
some people buy office entry mats from Wal-Mart or CostCo and 3M carpet tape it to the roof.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#13 | |
http://www.pcmotorsports.org/ "I hate that..my rear fell in a hole and my front end got uncomfortably light, and I got a bit rattled & barked a bit..." ~RaggedOleMan~ Red Jeep Club Member #552 |
#14 |
Wow! Great ideas and advice guys...thanks much!
Maybe to clear up an issue regarding my tub & carpet, I should explain that I have no carpet in my heep except the front floor mats. I plan on Herculining the entire tub, front to back, but that's not til next spring. My thinking on the interior insulation on the roof is the fact that most of heat loss is because heat rises and anything I can do to mitigate that would be beneficial. I do have a Coleman propane heater that's built to run safely inside the cab of a vehicle with very little natural air ventilation, so that will help things. A dual battery is planned, but the Coleman should look after the heating issue like an electric fan would. I'm simply trying to minimize the loss of heat through the top of the roof because, as mentioned, heat rises. I realize that I'll still have to idle my engine or run the propane heater once in awhile, but I'd like to minimize that as much as possible (especially for the engine idling sake). Thanks for all the input guys. Your help is appreciated. Keep the great ideas coming!
#15 |
Heat does rise, but the difference in interior temperature between the roof and floor is probably very small. Heat is going to be transferred wherever there is a difference in temperature, so the floor is a large area of concern. The Herculiner may help insulate the floor better, so if you can do it now, it might make winter a bit more bearable.
I've sat in an F350 for twelve hours when it was in the single digits many times, and the heater was putting out the whole time just to keep it bearable. I can only imagine what a Jeep cab would feel like during that same time. Good luck out there this winter.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
