hardtop headliners/Insulation - JeepForum.com
post #1 of 8 Old 01-26-2006, 11:23 AM Thread Starter
wdyman
Anyone have pics or ideas of insulating a hardtop for noise and temperature control? Thought about just putting some thin indoor outdoor carpet up there but just curious about some better options. Also considered the spray in sound deadener that would also help insulate but would like some feed back on that also.
wdyman is offline
post #2 of 8 Old 01-26-2006, 11:26 AM
RAAB3485
Viewer Discretion Advised
RAAB3485's Avatar
If you really want sound deadening, you could line the roof with Dynomat (expensive in stores, dirt cheap on ebay) and then cover it with carpet. Then it would look nice, be insulating and sound deadening. And then after you do it you have to do a step by step write up and email me all the details so I can do it to my girlfriends TJ.
Eric
RAAB3485 is offline
post #3 of 8 Old 01-26-2006, 12:06 PM
LoneJeeper
i wear foil underwear too
LoneJeeper's Avatar
2013 MJ Comanche
you could also go to california tops , deal with potentially bi-polar customer service, and get a thinsulate liner.... or... ask said potentially bi-polar company owner for some hi-res pics and build it yourself.
I used about 3 yards of 400g thinsulate.
lj
ಠ_ಠ
LoneJeeper is offline
post #4 of 8 Old 01-26-2006, 12:08 PM
cheesycook
Accident Prone Bonehead
cheesycook's Avatar
There was a guy on Ebay selling something for that a while back. Pretty good idea actually. Take a thick piece of felt, measure the width of your rollbars and the length from your windshield to the rear, cut the felt so it is a little wider and sandwich it in between. If you go with sound deadener/insulator Dynamat makes a good spray,....but it is pricey. You could go really trick and upholster the inner side of the hard top.
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top.
tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
, because I don't have a clue, but Stu does!
cheesycook is offline
post #5 of 8 Old 01-26-2006, 12:08 PM
BeerMonkeY
i carpted my old yj hard top but when the sun hit it for the whole daythe spray adhevisive loosend up and fell off
'92 YJ
'98 ZJ 5.9
'13 WK2 HEMI
BeerMonkeY is offline
post #6 of 8 Old 01-26-2006, 12:19 PM
cheesycook
cheesycook's Avatar
I bet that was fun to clean up! What adhesive did you use? I only use 3M because I have seen results like that in cars with other stuff.
Hermiston, ORL
post #7 of 8 Old 01-26-2006, 06:49 PM Thread Starter
wdyman
I bought the liner from California Tops and it did not work very well, definetly not worth the money. I live in Arizona and when it got hot inside the adhesive velcro that held the liner in place fell down. The only thing the liner did was help with some of the heat transfer from the top, not much for sound reduction. Just a big side note. I WILL NEVER BUY FROM CALIFORNIA TOPS AGAIN. They would not respond to any of my emails or phone calls when I wanted to return a defective part. I finally had the credit card company I used deal with them and got a full credit but what a pain in the a$$.
wdyman is offline
post #8 of 8 Old 02-05-2006, 01:06 PM
acejeep
If you've ever read one of his replies RE - Defective Anything Return, he did you a favor. Unless you like getting emails filled with obscenities ...........
I'm no prude but I'm surprised somebody has driven up to Canada and whipped his a$$.
He's a very "special" person. Got me once, never again.
Knowledge is what we get from reading the directions.
Experience is what we receive from not reading the directions.
acejeep is offline
Hardtop insulation ideas for Canadian winters? VanBCguy TJ Wrangler Technical Forum 34 02-04-2013 09:43 PM
hardtop insulation CreepyCrawler95 YJ Wrangler Technical Forum 8 01-04-2010 08:58 AM
Headliners Jeep25 Wrangler General Discussion 1 02-03-2009 01:35 PM
Hardtop insulation fowlball TJ Wrangler Technical Forum 2 02-26-2008 01:37 PM
Headliners dman22 TJ Wrangler Technical Forum 13 03-01-2007 01:15 PM
