Hardtop door seal - JeepForum.com
post #1 of 8 Old 11-10-2008, 03:56 PM Thread Starter
leukus
Hardtop door seal
So i just added a hardtop to my jeep for the first time for the colder months. And it seemed like i had a better seal fron the hard doors to the surrounds then i do to the hardtop. Top is nice a warm - less road noise but the wistle going down the highway from the lack of seal around the doors is driving me nuts. Is this just the way it is? I am only noticing it because the top makes all the road noise so much quieter? Anything i can do to help?
Thanks
leukus is offline
post #2 of 8 Old 11-10-2008, 04:50 PM
2jhanna
You can try to adjust the latch striker pin (part that latch hits on the door jam) in a little. Loosen screws and move in a little. If you go too much, the rear edge of the door will look recessed into the body.
Also have you checked the rubber seal all around the edge of the door, may be torn in places.
jhanna
denton county, tx
2jhanna is offline
post #3 of 8 Old 11-11-2008, 09:34 AM
Wif
Wif's Avatar
First thing I'd check is that you have the top fitting correctly.
Is the side by the doors sitting flush to the body .. in other words does the inner edge where the door fits to line up and seem level between top/body ?
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline
post #4 of 8 Old 11-11-2008, 10:58 AM
BlueFlame
BlueFlame's Avatar
Could door upper part (frame around the window) be bent?
My doors seal extremely well to the hard top - exactly the same to the hardtop as they did to the softtop door surrounds.
BlueFlame is offline
post #5 of 8 Old 11-11-2008, 11:12 AM
Wif
Wif's Avatar
Originally Posted by BlueFlame View Post
.. My doors seal extremely well to the hard top - exactly the same to the hardtop as they did to the softtop door surrounds.
So does mine .. no drafts or whistles.
Originally Posted by leukus View Post
So i just added a hardtop to my jeep for the first time for the colder months. ..
Is this a top you've just bought .. have you had it on before ?
If it's new is it a pre 2003 top .. in other words does it have the air vents at the rear behind the side windows ?
Formally 88Jeepster
Who's in front ?
Wif is offline
post #6 of 8 Old 11-11-2008, 07:46 PM Thread Starter
leukus
yes i just bought it. It is a top off a 2003 that i put on my 2000 TJ. As far as i can tell the upper doors are not bent. It is both side - so i will check it out with how i have it mounted.
Thanks
leukus is offline
post #7 of 8 Old 11-11-2008, 10:30 PM
Wif
Wif's Avatar
That could be the issue. 2003 tops do not have the rear vents behind the side windows (2003 Jeeps have the vent in the rear door behind the spare tire).
Air getting thru the front heater vents has nowhere to escape out the back. If the top is sealed airtight it could cause whistling.
Formally 88Jeepster
Who's in front ?
Wif is offline
post #8 of 8 Old 11-12-2008, 04:01 PM Thread Starter
leukus
so in that case i guess it is what it is.
thanks
leukus is offline
Hardtop Seal thyslip YJ Wrangler Technical Forum 5 11-17-2009 09:24 PM
Repl Tj 1/2 door seal, lost door hinge nut Oldbill51 TJ Wrangler Technical Forum 4 09-29-2009 03:53 PM
Can not seal the gap from upper door and door frame moldham YJ Wrangler Technical Forum 3 10-22-2008 12:10 PM
YJ full steel door... anyway to seal the gap left between rollbar and door ? intenseblu YJ Wrangler Technical Forum 6 06-11-2007 08:07 PM
Hardtop/Door Seal Issue? SimonTuffGuy YJ Wrangler Technical Forum 8 12-05-2005 06:35 AM
