#1 | |
Hard Top Wiper Wiring Question
I just got a hardtop for my 2000 TJ and was woundering if it was possible to wire a switch in for the rear wiper? How about the defrost? I dont feel like spending 100+ dollars for the wiring harness right now. I was woundering if I can hook a switch up in the dash and have it turn the wipers on and off and likewise for the defroster.
Thanks, Cody
#2 |
Junior Member
The wiring harness that I put on my 06 about a month ago is pretty extensive to hook up... It has little pins that you have to push into the factory plugs. I am sure that you can use a 12 volt power source and some type of relay design to get them both working but I would just recommend buying the harness. Just my .02
#3 |
I think the defrost would be easy enough. Problem you might run into is overheating. OEM is designed to turn off when it reaches temp, I believe. The wiper is more difficult. Just the time and money to make it work probably makes the harness look like a bargain.
I'd keep looking for a cheaper harness online. |
#4 |
Coming from a guy who just installed one on his '97 TJ last weekend: Find the complete wiring kit. I picked one up from jeepsareus.com with everything you need. It was about $120 and came with the complete harness, connectors, plugs, a new fluid jug, pump, relays, and switches. The instructions it came with are perfect and complete. It took me about 2-3 hours to finish it all up. It was worth the $120 in my opinion.
1997 TJ - 3" FT, 31's on Crager Soft 8's, SYE/CV Drive shaft, RE Adj. UCAs, 2 Hella 550FF's, Dual tops... |
#5 |
cool thanks for the input. I will just shop for a harness
#6 |
I also installed the kit. The kit does have everything. The instructions could have been a touch better by adding some written text instead of all pictures.
The defrost is on a timer circuit. 10 minutes. |
#7 |
this is kinda related
on my 99 factory hardtop the rear defrost stopped working , the indicator light will still lightup when I press the defrost switch but I wont get any defrost action. all the fuses under the hood seem to be good |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
