Hard top glass will not open - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Hard top glass will not open
Metalcloak's Black Friday & Small Business Saturday SaNEW!! HMF 50"-52" light bar mounting brackets!! NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WD
Unread 10-21-2014, 01:07 PM   #1
Jessa
Hello. I can't seem the get my glass lift gate open on my 2003 Sahara. I'm not sure if this is a fuse issue or if it's completely broken. Any advice would help. Thank you.
Jessa is offline   Reply With Quote Quick reply to this message
Unread 11-12-2014, 02:58 PM   #2
00tj2
Have you tried opening the tailgate and then trying to open the glass? I'm confused on why you would think its a fuse? Or do you mean the struts might be rusted thus preventing it from opening?
00tj2 is offline   Reply With Quote Quick reply to this message
Unread 11-12-2014, 03:22 PM   #3
Jessa
It worked perfectly fine one day and stuck the next. Nothing is rusted and everything is lubed up. Maybe its the hydraulics? I thought fuse because the wiper stopped working as well. It opens a few inches and stops like it's locked or something. Thank you for your responce!
Unread 11-13-2014, 01:16 PM   #4
00tj2
Maybe you can climb into the back and try disconnecting the struts and see if it will raise that way. If so you know they are bad, just be careful because they are charged and will fully extend.
Unread 11-13-2014, 05:56 PM   #5
Jessa
I will try that. Thank you!
