Hard top bolts - JeepForum.com
post #1 of 8 Old 11-01-2006, 04:13 PM Thread Starter
emschris
Oops, sounds expensive!
emschris's Avatar
Hard top bolts
Anyone know where I can get a bolt set for my hard top, or can tell we what hardware I would need to piock up form the local lowe's. I seem to remember some clips but really recall. I can't seem to locate them and I 'd like to get the top on.
(81 CJ, 92 YJ, 97 TJ, All Gone) 05 TJ Rubicon
Stupity Kills, but not nearly enough.
emschris is offline
post #2 of 8 Old 11-01-2006, 04:26 PM
daveg13
daveg13's Avatar
Regular old bolts, nuts, and washers will work fine.
daveg13 is offline
post #3 of 8 Old 11-01-2006, 04:48 PM
tomk864
http://www.trademotion.com/partlocat...=2&catalogid=2
Screws are $1.23
Nuts are $2.24.
x6 each.
You'd be much better off going to the hardware store...
The only thing about the factory nuts are that do not need a wrench due to the way they set under the rail...
tomk864 is offline
post #4 of 8 Old 11-01-2006, 06:18 PM Thread Starter
emschris
emschris's Avatar
Oh yeah, It had a square bolt that locked in underneath the rail. I think I'll go the hardware store route. Thanx for the help.
emschris is offline
post #5 of 8 Old 11-01-2006, 08:37 PM
halfmoonclip
Do yourself a favor and order OEM stuff from jeepsareus (www.jeepsareus.com)
They don't cost much, and starting a hex nut underneath the rail is just a bunch of pi$$ing around.
The factory part also has a plastic clip that keeps the nut in place.
Be patient and do it right.
Moon
'04 Rubi, manual, usual options, Hella H-4s, any range lockers, Randy's booster seats, Oly pushbar, 245/75R16 BFG
'09 Audi A4 Avant- my bride's schnellpuffenpanzer
'12 Ford Focus-the sure way to get good Jeep mileage
'07 Dodge Caliber R/T AWD-da kid's ride
Goodbye Old Blue XJ; 10+yrs, 100K+ miles; virtually trouble free; Long may you run!
halfmoonclip is offline
post #6 of 8 Old 11-01-2006, 08:54 PM
newracer
Or get the quick release kit that allows you do install and remove without tools.
newracer is offline
post #7 of 8 Old 11-01-2006, 09:04 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
i got some big ole eye bolts and wing nuts for the bottom. and a set or washers for the top.
put a wahser on the eyebolt so it doesnt dig out the hole in the ahrd top, then put the wing nut under the lip and turn the eye bolt, the wing nut will brace itself in place, and the ye bolt is big enough to tunrn with your hand. i think i got 1/4th inch bolts. also, they rpoovide a handy tie-down spot
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #8 of 8 Old 11-02-2006, 05:55 AM
Combatsylvania
Yep, for as often as you pop it on and off this is a good route to go.
You can also use 2 nuts, one on top and underneat to set the height of the eye bolt and orientation..
I've tried those clamps pictured above, they work but you really gotta tighten them alot. Also with bolts the top "parks" itself in the perfect spot every time. When I had the clamps on i noticed the top wasnt always in the perfect spot.
I bought my top with no bolts and 4 dollars later Im happy as a pig in poop
Combatsylvania is offline
Eye bolts through hard top NJscott YJ Wrangler Technical Forum 11 10-11-2009 10:32 AM
Hard Top Bolts Punching Through Hard Top! UGH! HELP? rchs.band JK Wrangler Technical Forum 16 12-01-2007 06:33 PM
Hard top bolts and roll bar bolts VanTheMan YJ Wrangler Technical Forum 4 04-16-2007 05:42 AM
Bolts for the Hard top Mike M TJ Wrangler Technical Forum 4 10-28-2006 03:09 PM
Hard top bolts lateapex TJ Wrangler Technical Forum 2 10-09-2006 01:33 PM
