Hard Starting - Engine cranks for a long time - JeepForum.com
post #1 of 9 Old 01-23-2010, 07:05 AM Thread Starter
ukgerald
Hi Guys, Just got back from a trip to Lake Tanganika where finding good quality fuel was an issue. I now have a problem starting the Jeep. I have searched under this topic and there are various options - the one I am leaning towards is the fuel pump return valve having failed. Symptoms are : Takes a long time of cranking before it will fire, once running it settles down smooth as ever. To get it to start a bit quicker I crank for a couple of seconds stop, then full throttle and crank again, it then starts pretty quickly. Was wondering whether there are any diagnostics that I can run myself - please bear in mind that I live in the Back of beyond, there is no dealership of reasonable repair centre within 2000km. If the fuel pump is the likely culprit pleas recommend an online company that I could use. Thanks all
If you outlaw guns - only outlaws will have guns!
ukgerald is offline
post #2 of 9 Old 01-23-2010, 07:09 AM
TheBoogieman
Dead Jeepers Club
TheBoogieman's Avatar
Turn the key to ON,but don't try to crank it for 5-10 seconds.If it starts up fine it's probably the anti-drainback valve.
TheBoogieman is offline
post #3 of 9 Old 01-23-2010, 07:35 AM
jeepgunner12
I TAP the gas when my Jeep does this. Starts every time no prob.
GREEN JEEP CLUB #385
PM me if you have an old hilift and/or a 31x10.5 R15 youd like to trade or sell, im in the market for a jack and a trailspare. Cheers!
jeepgunner12 is offline
post #4 of 9 Old 01-23-2010, 08:05 AM
jezow2010
Start your jeep and run it for a minute or so then leave it sit for a half hour to an hour then go to the bleeder on your fuel rail (looks like a large valvestem) and take the cap off and try and bleed the pressure off it. If it has pressure then its not your fuel pump assembly.
jezow2010 is offline
post #5 of 9 Old 01-23-2010, 08:14 AM
SkylinesSuck
x2 on that. Also one thing to keep in mind. As long as you have the battery power to support it, it's actually probably a good thing to crank it a bit before it fires. It gets just a bit of oil pressure built up and things moving before the engine sees the wear and tear of start up. Mine takes a few seconds to start and I know it's the anti-drain back valve. I'm happy it does it and don't plan on fixing it, but I also know I can just turn the key to "run" for a few seconds then try to start it if I do want it to fire off quickly (like if some girls are watching or something).
'98 Sahara w/AX15 & 4.6L stroker, 2.5" OME lift, 32" BFG M/T's, 8.8 w/Detroit Trutracs & 4.10's F&R
SkylinesSuck is offline
post #6 of 9 Old 02-07-2010, 03:01 PM
JeepRob98TJ
Hard Starting Engine
I have this same issue... I had the engine torn apart for 3 weeks of so replacing a piston and rings and rod bearings. And ever since I put it back together it has been starting hard.
I tried what was mentioned above and it started better.. ( turning the key to the On position for 5-10 seconds before starting). Where is this anti-drainback valve located if I wanted to replace it?
Thanks
Rob
JeepRob98TJ is offline
post #7 of 9 Old 02-07-2010, 03:06 PM
NotURMailman
NotURMailman's Avatar
Thanks
Rob
Unfortunately it's part of the pump assembly. You can put an inline check valve from McMaster Carr in the supply line as close to the tank as possible...
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #8 of 9 Old 02-08-2010, 08:41 AM
JeepRob98TJ
That is what I thought but could not verify it.... Thanks...
post #9 of 9 Old 12-23-2010, 01:03 AM Thread Starter
ukgerald
Thanks all, meant to get around to this reply some time ago. ordered in a new pump assembly and fitted it (alone and on the floor - what a pain in the ***). It solved the problem straight away. Thanks for the advice and help.
ukgerald is offline
91+ Hard or No Start/Long cranks in the cold explained sentinal02 YJ Wrangler Technical Forum 72 04-09-2017 11:04 AM
97 TJ cranks for a long time before start mflint1513 TJ Wrangler Technical Forum 17 11-06-2013 11:34 PM
jeeps having a hard time starting t-bird TJ Wrangler Technical Forum 24 11-08-2009 10:29 AM
Cranks a long time before starting. RH31379 YJ Wrangler Technical Forum 11 10-23-2007 02:23 PM
Hard time starting BumbleBeeTJ TJ Wrangler Technical Forum 1 10-05-2004 10:27 AM
