hard to shift - JeepForum.com
post #1 of 10 Old 03-10-2011, 02:51 AM Thread Starter
offroad1
hard to shift
Hey guys. Got a 97 wrangler. 4cyl 5spd. Its really hard to get it into gear. Like most of the time I've really gotta force it into gear.... Any suggestions. The jeep has 225000miles
offroad1 is offline
post #2 of 10 Old 03-10-2011, 06:56 AM
mdm
Farm Wheeler
Does it grind when you try shifting into a gear or is it just stiff? Does it shift any differently when the engine isn't running?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 10 Old 03-10-2011, 08:35 AM Thread Starter
offroad1
It only grinds going into reverse. When the engine is off it shifts effortlessly. Just like its suppose to.
offroad1 is offline
post #4 of 10 Old 03-10-2011, 01:28 PM
bippity
My jeep has a similar problem, It grinds a bit when putting the shifter into 2nd, only when downshifting though. Reverse also grinds a bit like yours.
It also has the same difficulty putting it in gear sometimes, especially reverse. I find that if I take the clutch out when in neutral and then put it in and try shifting again it goes in smoother. I'm talking about at a dead standstill, I go to put it in reverse and something stops it unless I put put both hands on the shifter and yank it into gear, but putting the clutch in and out fixes it.
bippity is offline
post #5 of 10 Old 03-10-2011, 06:03 PM
jeepoffroad18
is it cold out? when its cold the boot tends to be stiff when its cold, and there is actually there is another boot you do not see underneath the one you do see. with the 2 boots geting stiff its makes it hard to shift and causes you to grind gears.
I always wave!!! I even wave at hummers.......i just use a few less fingers.... if u know what i mean! hahaha
jeepoffroad18 is offline
post #6 of 10 Old 03-10-2011, 06:06 PM
freeskier93
FYI reverse is an unsynchronized straight cut gear, so obviously its going to grind and be harder to shift into.
OP, its a 14 year old transmission with over 200k miles! What do you except? Synchros wear out, either put up with it or do a rebuild.
freeskier93 is offline
post #7 of 10 Old 03-10-2011, 06:07 PM
rudedog231
original clutch? could be wore ,slave cyl.at end of stroke
LEAD,FOLLOW,OR GET THE F**k OUT OF THE way!!! 99' wrangler sport. RED JEEPS ROCK!!!
rudedog231 is offline
post #8 of 10 Old 03-10-2011, 06:09 PM
purplepig
Check this out first. I was having problems when it was cold. I took the accordian shift boot off and made a new one out of a longsleeve shirt. It helped alot.
Try some good oil in there, too.
purplepig is offline
post #9 of 10 Old 03-10-2011, 06:17 PM
ek1
when is the last time you changed the fluid? I had this problem on my ax-15 when I first bought my jeep. I changed the fluid to Redline MTL and it cured the hard shift problem.
As for reverse, try dropping it in 4th first, then reverse. Shouldn't be any grinds.
ek1 is offline
post #10 of 10 Old 03-10-2011, 07:45 PM Thread Starter
offroad1
Yeah its the original clutch. I'm gonna change the fluid and get it looked at. Just looking for some ideas as to what it could be. Thanks for all the help
offroad1 is offline
hard to shift RH31379 YJ Wrangler Technical Forum 5 12-18-2007 10:22 AM
Hard to Shift... bigchevyman24 TJ Wrangler Technical Forum 3 10-05-2007 02:06 PM
Hard to shift Wmorgan1995 YJ Wrangler Technical Forum 2 06-04-2007 06:37 AM
Hard to shift samger2 TJ Wrangler Technical Forum 2 11-07-2005 04:11 PM
AX-15 hard shift in 1st & 2 ed RussW YJ Wrangler Technical Forum 1 03-12-2003 06:06 PM
