Hard to get in reverse. - Page 2 - JeepForum.com
post #16 of 24 Old 06-19-2017, 02:42 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by Adam013085 View Post
No it usually doesn't grind but sometimes I have to shift to first before R.
That is absolutely 100% normal and the way it should be since Reverse is not synchronized in your transmission. My old '66 VW beetle was like that, Reverse wasn't synchronized in it either. You just need to shift into a forward gear first before shifting into Reverse to eliminate and prevent it from grinding. Gears 1-5 are synchronized in our transmissions, Reverse is not.
Jerry Bransford is offline
post #17 of 24 Old 06-19-2017, 02:44 PM
Adam013085
Yup that's what I typically do now too. Its grinded a couple of times but try not to
1998 Jeep wrangler
2.5
31x10.50x15 tires.
Adam013085 is offline
post #18 of 24 Old 06-19-2017, 03:32 PM
btn
Another thing to try: If you're stopped and the engine is running and the clutch isn't pressed, the countershaft will be spinning in the transmission. When you do press the clutch to shift into reverse, wait a second before shifting. It'll give the countershaft time to stop spinning, and then you don't get the grind on the reverse shift.
I've had to start doing that now that I switched to an AX15 without a synchronized reverse, from the NV3550 which had a synchronized reverse.
2000 TJ, 4.0L, 4" suspension lift, 35s, rear D44 and front HP30 both with ARBs. AX15, 4:1 T-case.
btn is online now
post #19 of 24 Old 06-19-2017, 03:35 PM
Adam013085
I'm guessing that's what I have done the 3 or 4 times where its grinded. It's something I do subconsciously so who knows. Now I can look at my wife and tell her in confidence there's nothing wrong
1998 Jeep wrangler
2.5
31x10.50x15 tires.
post #20 of 24 Old 06-19-2017, 04:11 PM
GeepWrnglr
No, not really. It just won't go in sometimes without the workaround. Sounds like yours might be a different problem. Sorry...Good luck...
GeepWrnglr is offline
post #21 of 24 Old 06-19-2017, 04:22 PM
Jerry Bransford
Administrator
Just shift into Reverse using the correct age-old technique described above and you'll never grind it so you would have to tell your wife there's nothing wrong again.
post #22 of 24 Old 06-19-2017, 06:18 PM
btn
Jerry, shifting into first is done to stop the countershaft from spinning? Makes sense because you could use the synchronized first gear shift to stop all the shaft motion, then move it back to reverse because all the gears are stationary then.
btn is online now
post #23 of 24 Old 06-20-2017, 10:17 PM
byoungblood
If shifting into another gear isn't working, I'd guess the input shaft may be sticking in the pilot bearing a little. I suspect this is what is going on with mine. I can shut the engine off and hear it spin down with the motor with the clutch disengaged so something is still making that input shaft spin.
byoungblood is offline
post #24 of 24 Old 06-22-2017, 06:42 PM
GeepWrnglr
Yes it was such an awesome post, once wasn't enough...that's the story I'm going with
reverse hard to use kyle7 YJ Wrangler Technical Forum 5 02-10-2010 04:39 AM
Hard to go into 1st and reverse bobmcc81 YJ Wrangler Technical Forum 10 08-24-2009 06:47 AM
Hard as Hell to get into 1st and reverse? 01blackws6 YJ Wrangler Technical Forum 10 01-10-2009 04:05 PM
manual, hard to get in reverse nashvillwill TJ Wrangler Technical Forum 15 12-30-2008 11:18 PM
Why is my TJ shifting so hard into reverse? bhicks TJ Wrangler Technical Forum 2 04-25-2008 08:14 PM
