Hard to get in reverse. - JeepForum.com
post #1 of 24 Old 06-19-2012, 03:49 PM Thread Starter
troge
My 98 TJ 2.5 with a manual 5 speed is sometime hopless to get into reverse.
I have to turn off the engine to get it in reverse. Whats wrong with my car?
troge is offline
post #2 of 24 Old 06-19-2012, 03:59 PM
Craft95ZJ
1986 MJ Comanche
Mine does this to me alot, 90% of the time I have to shift into first then go into reverse and sometimes I can try to shift into reverse and release the clutch halfway and it will fall into gear.
BTW Welcome to the Forum, and best of luck!
Daily driver '01 TJ 3" RC lift
'86 MJ 3.4L interior rebuild in progress.
Craft95ZJ is offline
post #3 of 24 Old 06-19-2012, 04:03 PM
M-RodPRO1
Hahah and I thought mine had clutch problems but now I know I'm not the only one having a hard time with reverse! Thinking on updating my transmission and hopefully that will be solved.
Follow My Build!
'99 Wrangler 2.5L
Red Jeep Club Member #543
M-RodPRO1 is offline
post #4 of 24 Old 06-19-2012, 04:06 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
There's no synchronizer for reverse.Shift into a forward gear and then into reverse to ease the grinding.
TheBoogieman is offline
post #5 of 24 Old 06-19-2012, 06:29 PM
heretic69666
I have the same problem with my 6 speed. Sometimes it will go straight in, sometimes I have to let the clutch out a bit, and when I'm in a hurry I just slam it home an hit the shifter on the console.
Maybe when I get rid of the TC drop it will fix it. Until then....... I just take it easy when backing up.
SUPPORT YOUR VETERANS!!!
heretic69666 is offline
post #6 of 24 Old 06-20-2012, 06:42 AM
samger2
Mine does the same thing...always has. I have to go into first gear then into reverse to avoid the grinding. Even with a new clutch still does the same thing.
samger2 is offline
post #7 of 24 Old 06-20-2012, 07:37 AM
JWebber
This is common, if you drive a jeep get use to it. As stated above no syncro' on reverse gear. So! grind it till you find it, or do the procedure stated above by boogie.
JWebber is offline
post #8 of 24 Old 06-20-2012, 08:31 AM Thread Starter
troge
But it cant be put in reverse even when it grinds a little. It is almost thats it is not any reverse there. When I push the shifter back into reverse and let out the clutch nothing happends. I must stop the engine or if I give full trottle sometime it goes into reverse. I dont understand whats wrong.
troge is offline
post #9 of 24 Old 06-18-2017, 07:26 AM
GeepWrnglr
Hello, my first time posting. I've had the same issue on my 95 YJ before my 5 speed transmission was rebuilt and since then. I've gotten used to it. When it doesn't want to go in, I put it in first and let out the clutch until it just starts to engage, then try it again. That usually works for me. Other than that, shifting is very smooth so for me, it turns out to be a very minor issue. Of course, that's me and my jeep, which may not work for everyone...
GeepWrnglr is offline
post #10 of 24 Old 06-18-2017, 07:31 AM
GeepWrnglr
post #11 of 24 Old 06-18-2017, 09:14 AM
TheBoogieman
Disturbed
Looks like it's your first AND second time posting. (OP 2012)
post #12 of 24 Old 06-18-2017, 09:22 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Is it grinding when you first try to engage Reverse?
Jerry Bransford is offline
post #13 of 24 Old 06-19-2017, 02:29 PM
Adam013085
Glad to know this is a common issue and likely not going to cause future issues since mine does this too
1998 Jeep wrangler
2.5
31x10.50x15 tires.
Adam013085 is offline
post #14 of 24 Old 06-19-2017, 02:34 PM
Jerry Bransford
Administrator
Does what? Is your complaint that it grinds when you shift into Reverse?
post #15 of 24 Old 06-19-2017, 02:35 PM
Adam013085
No it usually doesn't grind but sometimes I have to shift to first before R. It doesn't happen often but from time to time. Normally it shifts perfectly.
1998 Jeep wrangler
2.5
31x10.50x15 tires.
reverse hard to use kyle7 YJ Wrangler Technical Forum 5 02-10-2010 04:39 AM
Hard to go into 1st and reverse bobmcc81 YJ Wrangler Technical Forum 10 08-24-2009 06:47 AM
Hard as Hell to get into 1st and reverse? 01blackws6 YJ Wrangler Technical Forum 10 01-10-2009 04:05 PM
manual, hard to get in reverse nashvillwill TJ Wrangler Technical Forum 15 12-30-2008 11:18 PM
Why is my TJ shifting so hard into reverse? bhicks TJ Wrangler Technical Forum 2 04-25-2008 08:14 PM
