Handling in the wet - JeepForum.com
post #1 of 15 Old 10-10-2002, 01:30 PM Thread Starter
Mike17112
Newbie
Handling in the wet
1 inch BFG AT's.
Mike17112 is offline
post #2 of 15 Old 10-10-2002, 01:46 PM
Red97Sport
is for me, i slid out a cuple weeks ago, and today i didnt spin out, but i cud feel the tires not getting alotta traction
'97 Tj Sport - Red
5spd manual
33" BFG Mud Terrains
3.5" Rubicon Express Lift
Red97Sport is offline
post #3 of 15 Old 10-10-2002, 01:48 PM
moose
trac-lock?
Do you have the TL rear? That can be a real PITA on wet roads:)
jm
jm
moose is offline
post #4 of 15 Old 10-10-2002, 01:48 PM
Black 2001 TJ
Yes it is for a few reasons... You have rear wheel drive (when 4wd isn't in use) and when there is no one in the back, there is very little weight in the back (most up front), so since you have some sweet a** torque on that puppy, you will fish tale around turns if you are taking turns as fast as you do when it is dry. Also remember that since it hasn't rained in a good bit, the roads will probably be slicker than normal... You just have to get used to it, then it will be fun!
Black 2001 TJ, 4.0L, 5sp.
Mods: Rubicon Express 3.5" Superflex, Adj. Front Trackbar,
, OME LTs, steering skid, JKS discos, and probably more :)
On order (thanks Uncle Sam): Jeeperman Rear Bumper/Tire Carrier, Upper Adj. CAs (front/rear), rear Adj. Track Bar, Oil pan skid, new steering skid, BPEs
http://jeephorizons.com
Black 2001 TJ is offline
post #5 of 15 Old 10-10-2002, 01:50 PM
lavoo
lavoo's Avatar
I've heard this a few times with AT's, mostly in the winter weather though, all I can say is just be catious on the ol' turns.
98 TJ , 4" sl & 1" bl, 33" BFG MT's, FourXDoctor rockers ,Poison Spyder Trail Stinger bumper & corner guards, Custom air tank rear bumper,Banks Header, Raingler nets, Warn 9000 ,... plus many extras..
lavoo is offline
post #6 of 15 Old 10-10-2002, 02:39 PM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
"at a resonable speed"
Hate to point out the obvious, but if it was a reasonable speed you wouldn't have spun out. Gotta go slow. Light rear + lots of torque = easy to lose traction. Keep the rubber side down!
Whybu1 is offline
post #7 of 15 Old 10-10-2002, 02:42 PM
Whybu1
Whybu1's Avatar
Hate to be the one to point out the obvious, but if you fishtail you aren't going a "reaonable speed". Light weight + high torque = easy loss of traction. Keep the rubber side down.
Whybu1 is offline
post #8 of 15 Old 10-10-2002, 04:15 PM
scartozi
It could be the BFG AT's. I use to have them on my jeep and my brother had them on his. We both noticed that they weren't the best tires on wet roads. Of course my foot is kinda heavy so that might have something to do with it.
BLACK JEEP MEMBER#6
98 Black TJ 4.0, 2in body lift, 33x12.50's, Hella lights, K&N Filter....and lots more.
93 Jeep Cherokee. 3.5" Sus. Lift, 5 speed,Borla, oh yeah....tow hooks.
http://community.webshots.com/album/45643911aInSof
scartozi is offline
post #9 of 15 Old 10-10-2002, 06:34 PM
Whybu1
Whybu1's Avatar
Age has nothing to do with it. If the back end didn't follow the front end (spun, slid, broke lose) then you were going too fast for the conditions. Could be the tires, could be the road, could be the speed. My point was that everyone needs to be careful in the wet or snow. There are many accident reports filed that start with "I wasn't going too fast but..."
Whybu1 is offline
post #10 of 15 Old 10-10-2002, 07:01 PM
weslaine
happens to me all the time. As everyone mentioned, its all about weight and rear wheel drive(when you're not in 4wd).
But its also about the short wheel base. You must drive in anticipation of the back end "going out" from time to time. Prepare for it, slow down.
My Wrangler has always slid out the back end on wet roads, even "hops" on dry bumpy roads if your speed is too much or you oversteer.
Drive safe.
97 TJ Sahara Black
weslaine is offline
post #11 of 15 Old 10-10-2002, 08:18 PM
weslaine
Sorry Mike, didn't mean to make it sound like I was giving you a driving lesson.
You asked if this is normal behavior for a jeep to "break lose". My answer is "yes".
97 TJ Sahara Black
weslaine is offline
post #12 of 15 Old 10-10-2002, 08:54 PM
Mark K
Mark K's Avatar
Originally posted by Mike17112
I ask a simple question and I get lectures on how to drive. I won't bother in the future.
Wasn't always that way 'round here... but seems to be happening more and more.
Mark K
Don't ask me! I just post what my dog [Emma] tells me to.
Member of:
Mark K is offline
post #13 of 15 Old 10-10-2002, 09:38 PM
jrtj2001
We have a winner!! SWB vehicles are not inherently good handling. Coupled with a light vehicle with a fairly powerful engine wet weather traction is pretty poor.
Jason.
2001 TJ Sport
NV3550
D30/D44
Skyjacker Steering Box Skid
Bulletproof Rocker Guards
Home-made Disco's
jrtj2001 is offline
post #14 of 15 Old 10-10-2002, 10:10 PM
tophillrod
tophillrod's Avatar
I would have to concur w/ the SWB being the culprate here - not any sort of bad driving... I have been used to driving Toyota 4x4's before my YJ and I have to say what I used to take at a "slower paced" corner in the truck cause my Jeep to turn sideways. I have learned sinve then but it took a few corners to sink in. Not everyone was born driving a Jeep.
'92 YJ 4.0 HO
2" SL 2" BL 33" BFG AT's (for now)
RE quick disco's
Warn tire rack
Dana44 rear w/ Track lock
4:10 gears
135k and running strong...
tophillrod is offline
post #15 of 15 Old 10-11-2002, 09:28 AM
Whybu1
Whybu1's Avatar
Mike17112, I wasn't trying to be rude or give you driving lessons. You asked if it was normal for the backend to breaklose and my answer was "yes' if you are driving too fast. That wasn't meant as a smart remark or any indication of your driving. Everything people have said here including those "helpful answers" that assured you that they have the same problem (they are also going too fast) are simply the factors that make "too fast" occur at a really low speed. I also have the felt the backend get loose on wet pavement and spun around playing in snow in a parking lot. Why, I was going to fast for the conditions . Haven't yet seen a Jeep slide out or get loose while parked. (although I did see a camaro slid across an ice covered parking lot once with no driver inside, that was weird). Don't get frustrated if all the answers here are not ones you like. Happens all the. Take everything with a grain of salt and use it how you will. Again, Sorry.
Whybu1 is offline
Getting the best handling on a TJ heyitsme TJ Wrangler Technical Forum 30 11-27-2008 03:25 PM
Wind and handling. jeepguy79 TJ Wrangler Technical Forum 31 05-14-2008 08:52 PM
Handling Improvement, Can TJ=JK? fastRob TJ Wrangler Technical Forum 43 01-17-2008 04:53 PM
handling issues dpiontek YJ Wrangler Technical Forum 1 05-04-2007 03:17 PM
Very Poor Handling?? Jwinecoff00 TJ Wrangler Technical Forum 3 05-03-2007 07:07 PM
