Hand Throttle Install Details - JeepForum.com
post #1 of 5 Old 06-02-2011, 07:46 AM Thread Starter
srlbotanical
There are a number of hand throttle install threads out there, so I'm not going to go into the full step-by-step detail. I did come up with a couple small tricks that I thought might be helpful to someone.
I used Shimano Deore thumb shifter. It's got a little bigger barrel then the last one I had so the throttle control is a bit better. I also like the left side shift better, it connects in the perfect spot for my index finger to control the lever.
The deore lever has a thumb screw so I can tighten it and hold a desired RPM or loosen it so it snaps right back to idle when released. The only time I tighten it is when I am winching from outside the jeep.
I conected the cable to the throttle body bracket in the location that cruise control would have been if I had it. I used a barrel adjuster with two fender washers to sandwich the bracket. You can find the barrel adjuster at any bike shop, it can be found on most bike brake cables and shift cables.
I just used an electrical crimp on piece to connect the cable as seen here. The trick is the little clip that retains the connector and keeps it from popping off.
This is a huge improvemnet over the last hand throttle I had set up. It's much easier for me to manipulate on the left side of the stick shift and I like the slower ramp-up of throttle that the larger deore barrel provides. I hope that helps someone out.
Two Trackers 4WD Club
Wheeling in West Michigan for over 35 years.
HIGHER POWERED!!
srlbotanical is offline
post #2 of 5 Old 06-02-2011, 07:50 AM
Burleson
Very nice. I like that location as well.
Burleson is offline
post #3 of 5 Old 06-02-2011, 11:28 AM
RockyMnt1
Where can I attached the cable if I have cruise control?
RockyMnt1 is offline
post #4 of 5 Old 07-11-2012, 09:58 AM
Staggito
thank you for the post, i think im going to follow your example and put one on my jeep. noticed any pros / cons yet?
Bad *** JEEP!
Staggito is offline
post #5 of 5 Old 07-11-2012, 10:10 AM Thread Starter
srlbotanical
It works well and has been on for a little over a year. I love it on long rocky trails where my foot would usually get tired. I also find it much easier to use when I need clutch, brake and gas at the same time...
No cons that I can think of, other than my wife driving the jeep and not knowing what it was for...
HIGHER POWERED!!
BL and budget MML combo install- how long and install details? jondotcom TJ Wrangler Technical Forum 11 10-17-2009 07:52 PM
Hand throttle Poke YJ Wrangler Technical Forum 17 04-05-2009 09:02 PM
My hand throttle install YJames90 YJ Wrangler Technical Forum 6 01-25-2008 08:00 PM
Hand Throttle Install FlyersFan2009 TJ Wrangler Technical Forum 10 04-12-2005 05:38 PM
My hand throttle install (Pics) Sia YJ Wrangler Technical Forum 2 07-31-2003 07:42 PM
