Quantcast Hand Throttle for Automatic Transmission - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Hand Throttle for Automatic Transmission
Spartan Lockers FREE SHIPPING Excellent PricesDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ
Old 12-18-2008, 06:42 PM   #1
Sccafire
KMG 365
Before you all think I am nuckin futz. I need it to increase RPM while I am running my OBA. Question is How would you run the cable outside since there is no shifter boot?
I am looking for suggestions. Possibly somebody has already done this modification and can enlighten me.
Thanks in advance,
Scott
"life is good at 2 MPH"
Sccafire is offline   Reply With Quote
Old 12-18-2008, 06:46 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
I recently reinstalled my old 5-speed's hand throttle back onto my new B&M automatic shifter after converting to an automatic. My shifter cable went through a hole I made in the rubber boot but the hand throttle cable can also be inserted down through the little slot in front of where the OE shifter lever goes through. There's a bit of a bend in the cable but not enough so the handle is stiff or binds at all.
While two reasons I reinstalled it was to hold engine rpms higher for winching and OBA use, the primary reason was it makes crawling over the rocks a lot easier and smoother. The last couple trails I used it on were sweet indeed, it allows much smoother application of power on really bumpy rough trails. Even with an automatic.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 12-18-2008, 07:57 PM   #3
Sccafire
KMG 365
Do you happen to have a picture?
Scott
Old 12-18-2008, 08:10 PM   #4
Jerry Bransford
Here ya go.
Getting Savvy...
Old 12-18-2008, 08:18 PM   #5
Sccafire
KMG 365
Thanks for the picture. Mine is all still in stock form. I guess I need to find a way to do it with out the cable binding.
Scott
Old 12-18-2008, 08:19 PM   #6
Jerry Bransford
It shouldn't bind even with the stock shifter if you are careful to route it properly. You should also be able to drill a hole through the bottom of the shifter floor plate to pass the cable through.
Getting Savvy...
Old 12-18-2008, 08:23 PM   #7
Sccafire
KMG 365
Again thanks for the help. What about getting it through the console itself?
Scott
Old 12-18-2008, 08:29 PM   #8
mudb8
want it rite or rite now?
mudb8's Avatar
sweet, another use for old bicycle parts!
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Old 12-18-2008, 08:33 PM   #9
Sccafire
KMG 365
I live about 12 miles or so from RE. I am just going to go over there and get it from them.
Scott
Old 12-18-2008, 09:45 PM   #10
05jeeper
Jeep Enthusiast
05jeeper's Avatar
Do you have a pic of how you hooked it to the throttle body?
2005 JEEP RUBICON
GROUP MEMBERSHIPS:
BLACK JEEP SOCIETY
TJ OWNERS CLUB
WAR VETERANS JEEP GROUP
WASHINGTON STATE JEEPS
05jeeper is offline   Reply With Quote
Old 12-18-2008, 10:04 PM   #11
IslandTJ
Drink Oregon Craft Beer!
IslandTJ's Avatar
Location: where I wheel: N 45º 36.663' W 123º 20.935', Oregon
I too have an automatic. I use mine for a steady throttle on rough terrain and to increase my RPMs during winching or for my air compressor. I went a different route when I installed mine - it's close to my hand between the 2 and 3 o'clock positon on my steering wheel. When I'm outside, I can easily reach in to adjust the RPMs.
1998 TJ Moss Green Sahara w/ numerous scratches & dents whose playground is on a tropical island that's 33 miles long and 4-12 miles wide, in year-round 82 degree weather.
[Edit] "Now jeepin in Oregon" [/Edit]
IslandTJ is offline   Reply With Quote
Old 12-18-2008, 10:12 PM   #12
05jeeper
Jeep Enthusiast
05jeeper's Avatar
I like that idea. What did you mount it to?
2005 JEEP RUBICON
GROUP MEMBERSHIPS:
BLACK JEEP SOCIETY
TJ OWNERS CLUB
Old 12-18-2008, 10:30 PM   #13
IslandTJ
IslandTJ's Avatar
I was walking through Home Depot looking for an ideal mount and I found it in a black drawer/cabinet handle. I just bought a handle with the largest diameter.
Old 12-18-2008, 11:04 PM   #14
05jeeper
Jeep Enthusiast
05jeeper's Avatar
Oh gatcha.. Great idea. I will have to use that one.
2005 JEEP RUBICON
GROUP MEMBERSHIPS:
BLACK JEEP SOCIETY
TJ OWNERS CLUB
Old 12-18-2008, 11:32 PM   #15
Sccafire
KMG 365
That is a great idea. Gives me ideas of other places I could mount it other than on the shifter.
Scott
Glock Forum
