halogen h4 vs. xenon hyper white - JeepForum.com
post #1 of 12 Old 10-07-2009, 07:18 PM Thread Starter
mJUSTINm
i'm pretty set on getting delta quad bar headlights, but i saw two options for them on 4wheelparts.com.. quad bar headlights with halogen h4 or quad bar headlights with xenon hyper white. which is better? could someone explain the difference? im going to the off road expo in pomona this weekend and this is something i want to order while im there, so i want to figure out exactly what it is i want before going. i searched but couldnt find anything comparing, or even explaining, the two.
-Justin
mJUSTINm is offline
post #2 of 12 Old 10-08-2009, 12:38 AM Thread Starter
mJUSTINm
bump for the night
-Justin
mJUSTINm is offline
post #3 of 12 Old 10-08-2009, 05:51 AM
coach-mike
If the hyper white is lens and seperate bulb conversion get it. The differance is white light VS the yellow. You will get about the same distance of light but because 90% of all cars are standard yellowish you will be seen more. I change all my lights in every car to hyper white or HID which is SUPER POWERFUL HYPER WHITE.. I personally think I can see better with them. JM2C.
coach-mike is offline
post #4 of 12 Old 10-08-2009, 10:26 AM Thread Starter
mJUSTINm
just for reference here are the two:
7” Round Quad Bar Headlight Kit, Xenon Hyper White by Delta
7 Round Quad Bar Headlight Kit, Halogen H4 by Delta
so a hyper white bulb is more white compared to halogen?
-Justin
mJUSTINm is offline
post #5 of 12 Old 10-08-2009, 10:43 AM
RuffTJ
Yes.
I have the hyper whites and I like them a lot. I would say go with those and you wont be disappointed.
RuffTJ is offline
post #6 of 12 Old 10-08-2009, 10:56 AM
h2oskikrazy
Hyper whites will give the white European Look to oncoming traffic. My experience has been that they are not as good putting the light on the road as halogen h4s, especially in bad weather-snow, fog, and rain. I bought some expensive hyper whites for my Lexus suv and ended up trading them for a brighter version of the factory halogens. I personally run IPF Fatboys in my TJ which are a type of H4 bulb. You'll need HID's to legally improve on those. Of course, if you want to just run off road, you could always put some 80/130 watt H4's in there and be about as bright as anything out there. So, if you are concerned purely about looks, the hyper whites may be for you. If you are concerned more about real on road performance, I would try a brighter halogen from my experience.
h2oskikrazy is offline
post #7 of 12 Old 10-08-2009, 11:00 AM
RuffTJ
Agreed that the xenon hyper white are not extremely bright if thats what the OP is looking for. But they are definitely brighter than stock and look great on the road. Plus, if later on you want to do a true HID conversion to make them way brighter you have the delta light housings which are really nice too.
RuffTJ is offline
post #8 of 12 Old 10-08-2009, 03:57 PM Thread Starter
mJUSTINm
i dont care how the light looks, i care how the road looks. i want to be able to see. so HALOGEN is the way to go then? i do a lot of driving in the mountains. dark roads, snow, rain, and some driving through the desert at night on a 2-4 lane highway traveling north. i want to be able to actually see whats ahead, to the side of me while im driving. sounds like halogen is what i want then.
i dont understand how having a certain kind of light looks cool. its purely function for me.
-Justin
mJUSTINm is offline
post #9 of 12 Old 10-08-2009, 04:54 PM
RuffTJ
then you need to buy new housings and do a HID conversion
RuffTJ is offline
post #10 of 12 Old 10-09-2009, 01:54 AM Thread Starter
mJUSTINm
i was kind of hoping to just do a replacement thing instead of the conversion. how much more is there to convert to HID? the easier installation is for me, the better. i dont know much haha
-Justin
mJUSTINm is offline
post #11 of 12 Old 10-09-2009, 04:03 AM
zachjf
I have Hella off-roads with halogen 100watt lows and 130watt highs running through a custom built harness, pulling power directly from the battery for power/ground and triggered by the factory headlight switch. They are brighter than anything else out there, including HID's, and I have yet to get flashed. The beam pattern of the Hella's has a sharp cutoff between low and high like an HID but the actual light output is pure white and very intense above/below the cutoff line.
The harness took me awhile to build but I also constructed it out of 10 and 12 gauge wire and solder jointed/heat shrinked every connection including the crimp connections. The conversion turned out so well in fact that after friends have seen them at night I've built 3 more just like it for them.
Needs parts?
PM
or
zachjf is offline
post #12 of 12 Old 10-09-2009, 06:58 AM
prljeep
I have the Delta Xenon for daily driving headlights- as mentioned they are not overly bright on low. However, I find them to be extremely bright on high beams. To me, the light pattern on high beams stretches very far outward and very high upward...compared to stock bulbs.
I also found that without my fog lights, it seems to be pretty dark until about 10 feet ahead of my car under certain conditions. I usually run with my fog lights on constantly, just in case something would dart out between the front of my car and the ten feet before my light hits.
IMHO
prljeep is offline
halogen headlights dubaispy YJ Wrangler Technical Forum 11 01-14-2010 01:15 PM
Hyper-Sensitive Steering hrjaw TJ Wrangler Technical Forum 15 01-09-2007 04:29 PM
anyone have hyper tec power programmer magnum629 TJ Wrangler Technical Forum 28 10-17-2006 06:12 AM
Silvian Star Headlight w/ Stock Fog Lights / Halogen Off Road Lights mferrari TJ Wrangler Technical Forum 3 03-29-2006 07:37 PM
halogen headlights. shookwell YJ Wrangler Technical Forum 6 07-06-2003 01:36 PM
