Half Hard Top - JeepForum.com
post #1 of 63 Old 12-01-2004, 12:45 AM Thread Starter
Black&Tan_TJ
Half Hard Top
Does anyone know if there is a Half Cab Hard Top available for TJ's? The only one I've ever seen is for the TJL http://trucktrend.com/roadtests/ulti...om/index2.html
Scroll down on the linked page.
But I have no idea how to get my hands on one since they are military vehicles.
Thanks
Jason
Black&Tan_TJ is offline
post #2 of 63 Old 12-01-2004, 12:48 AM
abstractjeep
well, what you gotta do is make friends with some military people....get them to bring it out one night, get them sloshed, and run off with it while they are puking in the bathroom!
other than that, i don't know...i've actually kinda looked for one myself, as i like my half top, but would like the benefit of a hard top during the winter and rainy seasons.
abstractjeep is offline
post #3 of 63 Old 12-01-2004, 01:08 AM Thread Starter
Black&Tan_TJ
Yeah, I like my half top too. There not for everyone, but I guess it depends on how you use the Jeep. They're great for putting smelly things like chain saws, and gas cans in the back so you don't have to smell the fumes.
I'm actually in the process of building a bulkhead to go at the front of the bed, to keep stuff from sliding into the bottom of the top and into the passanger compartment. If that turns out good I may try to build a top myself. I'm pretty good with fiberglass. but I don't know if I'm that good. I would rather find one that I could just buy.
post #4 of 63 Old 12-02-2004, 09:54 AM
ncb76
ncb76's Avatar
Does AEV sell one, like they use for the Brute conversion?
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline
post #5 of 63 Old 12-02-2004, 10:05 AM
nemesistic
Junior Member
If you are good with 'glass, you will recognize the top as being constructed from SMC (sheet molded compound) and as such will require the special polyester resin or epoxy to work.
The reason I mention this is that it would be viable to purchase a damaged hardtop for a few pennies on the dollar and split it at the right spot, eliminate the side windows and rejoin the two halves into a half top.
The only issue becomes fitting to top of your bulkhead to bottom of the curved areas on the top and working out that transition.
The biggest issue become reinforcing the main hoop to eliminate the rear bracing. Can be done, but high levels of creativity are involved.
nemesistic is offline
post #6 of 63 Old 12-02-2004, 10:58 AM Thread Starter
Black&Tan_TJ
This is the route I had concidered If I had to build my own. Using the reminates of a full top eliminates many of the problem areas, such as the windshield and door frame attachments. The remaining trouble spots are sealing the bulkhead to the tub, and to the cut down full top. I already have the lower portion of the bulkhead built so the tub issue is not a problem. The biggest obstical now is what to do around the rear roll bars. I either have to make a two piece back to the top, or cut the rear bars off. I don't have passangers back there so the protection is not needed, but I think that they provide extra support for the front of the cage. I could strengthen the front of the gage with some cross bars for added safty.
If I cut the rear bars off, I think that I would be able to use an AEV half top if they will sell one seperate from the Brute conversion. Going this route would require the least fab work, because I would probley only have to redo my bulkhead to match their top.
Thanks for any ideas and opinions.
Jason
post #7 of 63 Old 12-02-2004, 11:15 AM
BNovak
BNovak's Avatar
Find a local truck cap company and see if they can make you one. There's a guy local to me that would make me a hard top for basically what everyone else wanted. I'm guessing he could make it a halftop as well.
Cool idea - never thought about this instead of the half-soft top I was looking at.
-BN
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill.
BNovak is offline
post #8 of 63 Old 12-02-2004, 11:37 AM
gr8tops
Vendor
gr8tops's Avatar
half hardtops
ask and you shall receive...
gr8tops is offline
post #9 of 63 Old 12-02-2004, 11:54 AM
01Sport
Donaghy, where did you get that?
2002 Grand Cherokee Overland. 2" BB. Moab Wheels.
Sold:
2001 TJ Sport :(
01Sport is offline
post #10 of 63 Old 12-02-2004, 12:25 PM
ncb76
ncb76's Avatar
so ugly...yet so cool
ncb76 is offline
post #11 of 63 Old 12-02-2004, 02:27 PM
wakeboarder 21
i think its only ugly because there are no rollbars
98 TJ
5spd,4banger
RE 3.5 __ 1" BL__RE front adj. trac bar__Currie Anti Rock sway bar__33 BFG M/T with some black steelies__K&N Filter__CB___ Durango 4x4 Front Bumper
building for 37s
wakeboarder 21 is offline
post #12 of 63 Old 12-02-2004, 02:59 PM
Falcor
Falcor's Avatar
Now that is cool.
2005 Unlimited
(sold) 07 JK Rubicon Unlimited, 97 ZJ Laredo - 4.0L, 98 TJ Sahara, 78 CJ-7, 88 Grand Wagoneer
Falcor is offline
post #13 of 63 Old 12-02-2004, 03:14 PM
Vacant Stare
Where DID you get that? Or did you build it?
Vacant Stare is offline
post #14 of 63 Old 12-02-2004, 04:39 PM
kg4fku
looks like a scrambler top. possibly slightly modified. ?????
kg4fku is offline
post #15 of 63 Old 12-02-2004, 04:51 PM
gr8tops
Vendor
gr8tops's Avatar
half hardtops
I am making them now and they are available for sale. That was the prototype/1st one we just finished up about a week ago and we are working a few small kinks out. A custom external "sport bar" setup is going in this week. I should have more pictures of the multi-function "sport bar" setup by early next week. (hi lift mount/basket rack/bike rack/tire carrier/gun rack/hunting stand etc). It does look very bare/odd without the rear rollbar. The factory interior cage is still there, we just cut the rear bars off. And we are still toying with different options on the rear "sport bars" and if/how to connect the outer sport bars to the interior cage. (yes I am trying to be legally use the officially correct legal terms for each)
The external sport cage just opens up endless options including work use for mounting small sprayer tanks, compressors, toolboxes, salt spreaders, etc..
gr8tops is offline
Half Hard Doors vs Full Hard....Key Cylinders Swappable? Hunta TJ Wrangler Technical Forum 17 05-13-2009 02:57 PM
Half Hard Top 10andrew28 TJ Wrangler Technical Forum 6 12-18-2008 12:54 PM
hard half doors/sliding windows/hard top tomthbomb YJ Wrangler Technical Forum 7 07-13-2007 07:42 PM
Half Top from Hard Top Mod? steveinmedford TJ Wrangler Technical Forum 7 04-03-2007 09:32 AM
Who was looking for a hard half-top? JAS95yj YJ Wrangler Technical Forum 4 12-19-2006 02:03 PM
