Half doors, no windows, no mirrors: what's the point? - JeepForum.com
post #1 of 17 Old 10-02-2012, 08:25 AM Thread Starter
dcdude2
I'm planning to run a safari top and half doors but keep my mirrors attached to the full doors and just run CJ style mirrors on the windshield frame. I would probably only replace the full doors every 3 years or so along with the soft top for skiing or something. I was planning on half doors with no windows. But with no mirrors, what benefit would these stripped half doors provide? Any notable wind protection? I guess they would help prevent you groceries from flying out?
Of course, there would be the cost and expense of sourcing and probably painting these doors.
dcdude2 is offline
post #2 of 17 Old 10-02-2012, 09:54 AM
dcope17
Put on your full doors and leave the windows down. If you see any benefit to this setup, then leave the full doors with the windows down or do what you said above.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #3 of 17 Old 10-02-2012, 03:28 PM
coach-mike
I run these but fabbed up my own mirrors as cops will nail u for no mirrors..
coach-mike is offline
post #4 of 17 Old 10-03-2012, 12:03 AM
Cresso
Compared to full doors, they don't provide a whole lot of warmth at highway speeds. If you do a lot of high speed driving during the colder months, keep your full doors around to swap on. Compared to no doors, the only highway benefit I've noticed is that I can wear shorts without feeling like the headwind is ripping the hair out of my legs. not worth it just for that.
At slower speeds, like around town and especially on the trail, the half doors are significantly warmer than no doors at all. Crank the heat and you'll get a nice little pool of warmth around your legs. It makes a big difference.
I run no doors on the trails where I expect body damage, full doors on snowbashing runs, and half doors the rest of the time.
The factory hard half doors are crazy expensive. I paid $250 for a pair that came with a broken sideview mirror and a busted latch (easily fixed). Depending on local availability, you might do better than that, but you might do a lot worse. I've seen folks paying upwards of $450 for a pair. After I bought mine, I took 'em to a body shop to color match them. They wanted $475 for the pair. I picked my jaw off the ground, took them home and painted them myself.
I don't like the tube doors on the market. I don't understand what they do. All of the inconvenience of solid doors without any of the desirable insulation effect. If I didn't want to spend the dough on factory hard half doors, I'd go for a set of the old CJ/YJ-style soft doors, like these. Lightweight, should take trail abuse fairly well, still blocks wind, and should be obtainable for a lot less than the hard doors. Yer pretty much stuck with the color you buy, though.
Cresso is offline
post #5 of 17 Old 10-03-2012, 08:35 AM
catmechanic
The benefit to me is the placebo effect it provides my wife, particularly on the highway. Since our daughter loves the jeep and we regularly have nieces / nephews around and wanting to ride with the top down, it provides her with a sense of security, however false it may be.
catmechanic is offline
post #6 of 17 Old 10-03-2012, 10:01 AM
Kinless
Amazingly the full half doors also keep an amazing amount of crap off your lap. Road Grime, literal crap ( cow,horse,etc ), mud.
Drive through a muddy area at normal speed one time and look at the amount of junk sprayed in an arc midway up your door. ( unless you are running real small skinny tires I suppose )
Kinless is offline
post #7 of 17 Old 10-03-2012, 10:18 AM
Zombi
Nice looking rig.
That statement depends on where you are, here in MA you're legal as long as you have at least 1 mirror, windshield mounted rear-view counts.
Just stumbled across this:
http://www.jeepforum.com/forum/f176/...r-laws-565361/
Call me Z
Originally Posted by mrbates View Post
Zombi's are in fact very unpleasant to be around, they smell, and bite--also, they eat babies.
Zombi is offline
post #8 of 17 Old 10-03-2012, 11:31 AM
frank_c
Ohio only requires one rear facing mirror. Your cops must be trolling for bigger offenses.
99 Wrangler Sport
99 Cherokee
87 J20
83 Wagoneer
frank_c is offline
post #9 of 17 Old 10-03-2012, 01:48 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I have tried all the set up you mentioned above. CJ style mirrors shake to much, it is a burden to remove door and mirrors a lot. I finally just broke down and bought a mirror re-locator for my driver door and threw the passager mirror in the tool box.
But back to the half door question, I have full doors, 2 piece soft doors, and no doors (of course). I use no doors the most. I use my 2 piece doors for trail riding or any off road excursion. But most of the time, I am doorless. I kind of wish I had not bought the 2 piece doors, but live and learn.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #10 of 17 Old 10-03-2012, 01:54 PM
TheRealKTrain
JK Wrangler
Im in the other boat. I WANT to find a deal on 2 piece doors, as I prefer to use them when its raining, and store them in the back the other 200 days of the year. I cant store full doors in the back of the jeep...
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #11 of 17 Old 08-23-2013, 05:45 PM
kbeitz
I just bought Half doors for my 2000. I have a light bar abouve the windshield and I put split half collars on both sides over the pipe that holds up the lights.
I will hook up two motorcycle mirrors to these collars. Quiick and easy.
kbeitz is offline
post #12 of 17 Old 08-23-2013, 05:49 PM
matthew900
matthew900's Avatar
I second this. The only reason I have 1/2 doors is my 9 yr old isn't comfortable with no doors.
matthew900 is offline
post #13 of 17 Old 08-23-2013, 07:36 PM
Jeepmanjoe52
In TN we don't even have to have a mirror unless we're driving commercially.
Jeepmanjoe52 is offline
post #14 of 17 Old 08-23-2013, 08:06 PM
2jhanna
This thread is almost a year old. But, I for one, really think there is a big difference between no doors and half doors (even with no windows).
Also, with stock mirrors only held in place by 3 screws, what's the big deal about moving them between doors.
jhanna
denton county, tx
2jhanna is offline
post #15 of 17 Old 08-24-2013, 07:08 AM
BigAl4102
Yep, IMHO half doors keep an amazing amount of dust and debris out of the cab. I think it has as much to do with aerodynamics, as coverage, my jeep with no doors gets way dustier and dirtier inside than with half doors even.
BigAl4102 is offline
Factory half doors windows and bestop soft doors??? cpleasant TJ Wrangler Technical Forum 0 04-29-2008 10:40 PM
Mirrors on half doors? keithgamble YJ Wrangler Technical Forum 2 04-29-2007 09:25 PM
New style mirrors on half doors? labsters TJ Wrangler Technical Forum 1 05-10-2006 08:40 AM
TJ Soft half windows on YJ half steel doors? DavesMatthew YJ Wrangler Technical Forum 5 04-17-2004 11:25 PM
mirrors and half doors BLACKLOCK TJ Wrangler Technical Forum 5 05-06-2002 03:03 PM
