Half door interior panel hole? - JeepForum.com
post #1 of 5 Old 08-01-2009, 07:23 PM Thread Starter
popeyesides
popeyesides's Avatar
I just bought steel half doors for my 06. I noticed a hole at the upper left corner kind of behind the mirror location (drivers side) and there is one on the passengers side, does anybody know what this hole is for. I pulled the panel off and there is a hole in the door behind it as well, should there be something there? also there is a gap between the panel and the door so I don't think a fastner goes there. Any help would be great.
popeyesides is offline
post #2 of 5 Old 08-01-2009, 07:31 PM
Rubicon_Rob04
It is a push in fastener, mine are color matched to the panel.
Rubicon_Rob04 is offline
post #3 of 5 Old 08-01-2009, 07:43 PM Thread Starter
popeyesides
Cool, thanks I guess I need to go to stealership and get one. I take it it is a lot longer than the short inside door panel ones?
post #4 of 5 Old 08-01-2009, 07:53 PM
Rubicon_Rob04
I believe so, its been awhile since I pulled them. I had to take my panels off to do some work on my lock cylinders last year and remember having a tough time getting them to come out. I could see where they would be easy to break, I think I just got lucky.
post #5 of 5 Old 08-01-2009, 08:12 PM
wanderer1951
Junior Member
wanderer1951's Avatar
2014 JK Wrangler
I had to work on the lock in my TJ, Even with care the plug broke.(yeah, thres a special tool for that) I went to Rural king and found something similar for less that a buck and used that. Was a real close match to the charcoal interior in the TJ.
wanderer1951 is offline
How do you remove the plastic half door panel beachedjeepyj YJ Wrangler Technical Forum 2 11-01-2009 10:32 PM
Half door interior panel bfr TJ Wrangler Technical Forum 1 01-20-2009 05:41 PM
Interior Door Panel Removal? rock2r TJ Wrangler Technical Forum 3 06-16-2005 12:24 PM
where to get TJ interior door panel? gnetcanada TJ Wrangler Technical Forum 5 07-06-2004 12:54 PM
Interior Door Panel Removal rock2r TJ Wrangler Technical Forum 6 03-19-2004 06:19 PM
